Resources and collections
The Astra Control REST API provides access to resource instances and collections of resource instances.
Conceptually a REST resource is similar to an object as defined with the object-oriented programming (OOP) languages and systems. Sometimes these terms are used interchangeably. But in general, "resource" is preferred when used in the context of the external REST API while "object" is used for the corresponding stateful instance data stored at the server. |
Attributes of the Astra resources
The Astra Control REST API conforms to RESTful design principles. Each Astra resource instance is created based on a well-defined resource type. A set of resource instances of the same type is referred to as a collection. The API calls act on individual resources or collections of resources.
The resource types included with the Astra Control REST API have the following characteristics:
Every resource type is defined using a schema (typically in JSON)
Every resource schema includes the resource type and version
Resource types are globally unique
Resource instances available through the Astra Control REST API have the following characteristics:
Resource instances are created based on a single resource type
The resource type is indicated using the Media Type value
Instances are composed of stateful data which is maintained by the Astra service
Each instance is accessible through a unique and long-lived URL
In cases where a resource instance can have more than one representation, different media types can be used to request the desired representation
Resource collections available through the Astra Control REST API have the following characteristics:
The set of resource instances of a single resource type is known as a collection
Collections of resources have a unique and long-lived URL
Every resource instance is assigned an identifier when it is created. This identifier is a 128-bit UUIDv4 value. The assigned UUIDv4 values are globally unique and immutable. After issuing an API call that creates a new instance, a URL with the associated id is returned to the caller in a Location
header of the HTTP response. You can extract the identifier and use it on subsequent calls when referring to the resource instance.
The resource identifier is the primary key used for collections. |
Common structure for Astra resources
Every Astra Control resource is defined using a common structure.
Every Astra resource contains the key-values shown in the following table.
Key | Description |
type |
A globally unique resource type which is known as the resource type. |
version |
A version identifier which is known as the resource version. |
id |
A globally unique identifier which is known as the resource identifier. |
metadata |
A JSON object containing various information, including user and system labels. |
The metadata JSON object included with each Astra resource contains the key-values shown in the following table.
Key | Description |
labels |
JSON array of client-specified labels associated with the resource. |
creationTimestamp |
JSON string containing a timestamp indicating when the resource was created. |
modificationTimestamp |
JSON string containing an ISO-8601 formatted timestamp indicating when the resource was last altered. |
createdBy |
JSON string containing the UUIDv4 identifier of the user id that created the resource. If the resource was created by an internal system component and there is no UUID associated with the creating entity, the null UUID is used. |
Selected resources a state
value which is used to orchestrate lifecycle transitions and control access.
