Astra Automation
Create a new execution hook for an app
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/executionHooks
Indicates the desired values for the Execution Hook API resource to be created.
account_id
string
path
True
  • example: {{.Account}}
app_id
string
path
True
ID of the containing app resource
Request Body
type
string
True
  • "application/astra-executionHook"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
name
string
True
JSON string containing a user-specified name for the resource. Defined values are:
  • Minimum length: 1
  • Maximum length: 63 Name must be unique across all execution hook resources.
hookType
string
True
JSON string defining the hook type. Defined values are:
  • "netapp" - NetApp provided execution hook.
  • "custom" - Tied to a specific app ID. Execution hook resources with hookType "netapp" are read only.
matchingCriteria
array[matchingCriteria]
False
JSON array of JSON objects describing the match criteria for the execution hook. When multiple matchingCriteria are specified a logical AND is applied to criteria. Defined values are:
  • Minimum items: 0
  • Maximum items: 10
action
string
True
JSON string indicating which action the execution hook will run assuming the match criteria are met. Defined values are:
  • "snapshot"
  • "backup"
  • "restore"
  • "failover"
stage
string
True
JSON string indicating the stage during the action that the hook will be executed. Defined values are:
  • "pre" - The execution hook will be run before the specified action.
  • "post" - The execution hook will be run after the specified action. Values for action "snapshot" are "pre" and "post". Values for action "backup" are "pre" and "post". Value for action "restore" is "post". Value for action "failover" is "post".
hookSourceID
string
True
JSON string containing the hook source ID that is run through this execution hook. Defined values are:
  • Conforms to the Astra Identifier Schema
arguments
array[string]
False
JSON array of JSON strings for the arguments to the source. Defined values are:
  • Minimum items: 0
  • Maximum items: 16
  • Minimum length: 0
  • Maximum length: 127
appID
string
True
JSON string containing the associated ID of the application that this hook is linked to. In essence, other matching criteria, if set. Defined values are:
enabled
string
False
JSON string that indicates if the execution hook is enabled. Defined values are:
  • "true" - The execution hook is enabled and will be run as specified.
  • "false" - The execution hook is disabled and will never run. The default value is "true".
description
string
False
JSON string containing a user-specified description for the hook source. Defined values are:
  • Minimum length: 0
  • Maximum length: 511
metadata
type_astra_metadata_update
False
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
Example request
  "type": "application/astra-executionHook",
  "version": "1.3",
  "name": "Payroll",
  "hookType": "custom",
  "action": "snapshot",
  "stage": "pre",
  "hookSourceID": "50e89023-ba84-435d-bb47-1833f4c250ff",
  "arguments": [
    "freeze"
  "appID": "7be5ae7c-151d-4230-ac39-ac1d0b33c2a9",
  "enabled": "true",
  "description": "Payroll production hook"
JSON
Status: 201, Returns the newly created executionHook resource in the JSON response body.
type
string
True
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
  • "1.3"
id
string
True
name
string
True
  • Minimum length: 1
hookType
string
True
matchingCriteria
True
  • Minimum items: 0
  • Maximum items: 10
matchingContainers
array[matchingContainers]
False
JSON array of JSON objects of each container that matches the configured matching criteria within the defined app.
matchingImages
array[string]
False
JSON array of JSON strings for the matching container images. Defined values are:
  • Minimum items: 0
  • Maximum items: 4095
  • Minimum length: 1
  • Maximum length: 255
action
string
True
  • "snapshot"
  • "backup"
  • "restore"
  • "failover"
stage
string
True
hookSourceID
string
True
arguments
array[string]
False
  • Minimum items: 0
  • Maximum items: 16
  • Minimum length: 0
appID
string
False
enabled
string
True
description
string
False
  • Minimum length: 0
metadata
True
  "version": "1.3",
  "id": "5f7e2e31-280d-5984-a28b-2d19ab5b77c0",
  "name": "Payroll",
  "matchingCriteria": [],
  "stage": "pre",
  "arguments": [
    "freeze"
  "enabled": "true",
  "description": "Payroll production hook",
  "metadata": {
    "labels": [],
JSON
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidFields
array[invalidFields]
False
List of invalid request body fields
  "status": "400"
JSON
Status: 409, Conflict
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "409"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
JSON
matchingCriteria
type
string
False
JSON string identifying the match criteria type.
value
string
False
JSON string containing a regex to match for the given match type. Regex syntax: https://github.com/google/re2/wiki/Syntax
type_astra_label
name
string
True
value
string
True
labels
array[type_astra_label]
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
matchingCriteria
type
string
True
value
string
True
type_k8s_label
name
string
True
value
string
True
matchingContainers
podName
string
False
JSON string of matching container's pod name.
podLabels
array[type_k8s_label]
False
JSON array of label objects of matching container's pod's labels.
containerImage
string
False
JSON string of matching container's image.
containerName
string
False
JSON string of matching container's name.
namespaceName
string
False
JSON string of matching container's pod's namespace name.
invalidParams
name
string
True
reason
string
True
invalidFields
name
string
True
Name of the invalid request body field
reason
string
True
Reason why the request body field is invalid
