Delete an application backup for an app
Deletes an application backup for an app. Use this endpoint to manage storage space by removing unnecessary or outdated backups.
HTTP method and endpoint
DELETE /accounts/{account_id}/k8s/v1/apps/{app_id}/appBackups/{appBackup_id}
Usage notes
Removes the specified Application Backup API resource. Backups in progress will be canceled, and then deleted.
Side Effects
If a backup is complete, the backup data is deleted.
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
appBackup_id |
string |
path |
True |
ID of the appBackup collection to list |
Status: 204, Indicates if the appBackup resource was deleted.
Status: 401, Unauthorized
| Name | Type | Required | Description |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/97",
"title": "Backup not deleted",
"detail": "The backup wasn't deleted because of an internal server issue.",
"status": "500"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/128",
"title": "Backup cancellation not allowed",
"detail": "A pending backup can't be canceled.",
"status": "409"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
