Delete a cloud
Deletes the requested cloud instance along with any non-managed clusters and volumes associated with it. Use this operation to remove cloud resources that are no longer needed.
HTTP method and endpoint
DELETE /accounts/{account_id}/topology/v1/clouds/{cloud_id}
Usage notes
Deletes the requested cloud instance and any non-managed clusters and volumes associated with that specific cloud.
account_id |
string |
path |
True |
cloud_id |
string |
path |
True |
ID of the cloud collection to list |
Status: 204, Indicates if the cloud resource was deleted.
Status: 401, Unauthorized
| Name | Type | Required | Description |
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/141",
"title": "Action blocked: Delete cloud instance",
"detail": "The cloud instance wasn't deleted because there are managed clusters associated with this cloud instance.",
"status": "409"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"type": "https://astra.netapp.io/problems/1",
"title": "Resource not found",
"detail": "The resource specified in the request URI wasn't found.",
"status": "404"
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
