Retrieve a credential
Retrieves a credential, providing the stored credential information in the response body.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/credentials/{credential_id}
Usage notes
Returns the stored Credential API resource in the JSON response body.
account_id |
string |
path |
True |
credential_id |
string |
path |
True |
ID of the credential collection to list |
Status: 200, Returns the stored Credential API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name. When a credential is created for a user, the name will be set to the UUID of that user. Defined values are:
keyType |
string |
False |
JSON string containing an optional user-specified data validation type descriptor for the contents of the keyStore. Extended update constraints:
valid |
string |
True |
JSON string describing whether the credential is valid for use. Default value, if omitted, is "true". Defined values are:
validFromTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is valid. These are used for credential rotation. Defined values are:
validUntilTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is no longer valid. These are used for credential rotation. Defined values are:
metadata |
True |
"type": "application/astra-credential",
"version": "1.1",
"id": "58e26f6a-a631-5122-8e0e-7afe306675c0",
"name": "myCert",
"valid": "true",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
