List all credentials
Retrieves a list of all credentials. Use this to view the available credentials in the collection.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/credentials
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: credential_1.1_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-credentials",
"version": "1.1",
"items": [
"f97f3441-075e-4f9b-9d1e-47f9f62a3fc4",
"myCert"
"5e365b4d-034f-4f13-95ef-d3a7fbc0df3d",
"kubeconfig"
"11ceb350-1999-4b79-80a6-46a980a27856",
"password"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name. When a credential is created for a user, the name will be set to the UUID of that user. Defined values are:
keyType |
string |
False |
JSON string containing an optional user-specified data validation type descriptor for the contents of the keyStore. Extended update constraints:
valid |
string |
True |
JSON string describing whether the credential is valid for use. Default value, if omitted, is "true". Defined values are:
validFromTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is valid. These are used for credential rotation. Defined values are:
validUntilTimestamp |
string |
False |
JSON string containing a timestamp indicating when the credential is no longer valid. These are used for credential rotation. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
