List the unread notifications for a user in a group
Retrieves unread notifications for a user in a group, providing a JSON array of the matching resources.
HTTP method and endpoint
GET /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/unreadNotifications
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
group_id |
string |
path |
True |
ID of the containing group resource |
user_id |
string |
path |
True |
ID of the containing user resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2"
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
orderBy |
string |
query |
False |
Indicates the sort order of resource when listing a collection. URL examples: "orderBy=name", "orderBy=name%20desc" OpenAPI examples: "name desc"
skip |
string |
query |
False |
Indicates the number of resources to skip over when listing a collection. URL examples: "skip=1" OpenAPI examples: "1" |
count |
string |
query |
False |
Indicates if the total number of resources should be returned in the metadata object. URL examples: "count=true" OpenAPI examples: "true"
continue |
query |
False |
Indicates the token to resume listing from. URL examples: "continue= OpenAPI examples: " |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: unreadNotification_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-unreadNotifications",
"version": "1.0",
"items": [
"4080cf5f-2261-4130-b8fb-8432e2e553e6",
48923
"1b4e89f1-2e70-4a08-a015-e7064b0fb703",
47345
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
notificationID |
string |
True |
JSON string containing a notification ID that is to be marked as read by the user creating the mark. Defined values are:
sequenceCount |
number |
True |
JSON number containing a sequence count associated with the notification specified by the notification ID. |
severity |
string |
True |
JSON string containing one of the following values that indicate the severity of the event. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
