Astra Automation
Retrieve an application backup
Retrieves an application backup, providing access to the stored backup resource for further inspection or recovery purposes.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/appBackups/{appBackup_id}
Usage notes
Returns the stored Application Backup API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
appBackup_id
string
path
True
ID of the appBackup collection to list
Status: 200, Returns the stored Application Backup API resource in the JSON response body.
type
string
True
  • "application/astra-appBackup"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
name
string
True
JSON string containing a user-specified name for the backup. If not specified, or when backups are initiated by a schedule, the system assigns a name for the backup. Defined values are:
  • Minimum length: 1
  • Maximum length: 63
  • Conforms to the DNS 1123 Label Schema
bucketID
string
True
JSON string containing an optional bucket ID that indicates where the backup will be stored on create. If not specified, a system-selected bucket is used. If no buckets are available, an error will be returned on create. Defined values are:
  • Conforms to the Astra Identifier Schema
snapshotID
string
False
JSON string containing the snapshot that was used to create the backup. To create the backup, a snapshot ID associated with the application being backed up can be specified on create. If not specified, a new snapshot will be created for the backup. Defined values are:
scheduleID
string
False
JSON string containing an optional schedule ID that indicates that the backup was triggered by a schedule and which schedule triggered the backup. Only present for backups initiated by a schedule. Defined values are:
state
string
True
JSON string containing a value indicating the operational state of the backup. Defined values are:
  • "pending" - The application backup is scheduled for discovery
  • "discovering" - The application backup is in the process of being discovered
  • "running" - The application backup is running normally
  • "completed" - The application backup has completed successfully
  • "failed" - The application backup is in a permanent failure state
  • "removed" - The application backup is not currently accessible
  • "unknown" - The application backup state cannot be determined
  • "deleting" - The application backup is scheduled for deletion
stateUnready
array[string]
True
JSON array of JSON strings, each indicating a reason why an application backup is unable to transition to "running", or why it has transitioned to "failed" or "removed". Defined values are:
  • Minimum length: 1
  • Maximum length: 127
stateDetails
array[type_astra_stateDetail]
False
JSON array of JSON objects which lists additional details about the current state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
  • Minimum Items: 0
hookState
string
False
JSON string containing a value indicating the state of any execution hooks run as part of a snapshot. Defined values are:
  • "failed" - One or more execution hooks have failed
  • "success" - There were zero or more applicable hooks and all were successful
hookStateDetails
False
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
  • Minimum items: 0
backupCreationTimestamp
string
False
JSON string containing a timestamp indicating when the backup was taken. Defined values are:
  • Conforms to the ISO-8601 Date Time Schema
totalBytes
number
False
JSON number containing the total number of bytes in the backup.
bytesDone
number
False
JSON number containing the number of bytes backed up for a running backup. When the backup is completed, it matches with the totalBytes field.
percentDone
number
False
JSON number containing the percentage complete for a running backup. When the backup is completed, it is set to "100".
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
  "type": "application/astra-appBackup",
  "version": "1.2",
  "id": "bab39d53-2d04-5297-b92e-58df89a2117b",
  "name": "app-name-245",
  "bucketID": "0afbe357-a717-4c7a-8b3d-d0368959c8de",
  "scheduleID": "1fe83650-9b3c-41ef-bb25-a2910c19c33e",
  "state": "pending",
  "stateUnready": [],
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 500, Internal server error
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "type": "https://astra.netapp.io/problems/95",
  "title": "Backup not retrieved",
  "detail": "The backup wasn't retrieved because of an internal server issue.",
  "status": "500"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
additionalDetails
type
string
True
title
string
True
detail
string
True
additionalDetails
additionalDetails
False
type_astra_label
name
string
True
value
string
True
type_astra_metadata
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
