List all application backups
Retrieves all application backups, providing a comprehensive list of backup resources available in the collection. You can specify individual fields in your request to tailor the information returned.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/appBackups
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: appBackup_1.2_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-appBackups",
"version": "1.2",
"items": [
"5cb608f9-571b-492e-a520-5bfb900a9b9c",
"app-name-245",
"pending"
"f8faa690-7e09-48a4-b33c-7965712acd0c",
"app-name-244",
"completed"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 500, Internal server error
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"type": "https://astra.netapp.io/problems/96",
"title": "Backups not listed",
"detail": "The backups didn't list because of an internal server issue.",
"status": "500"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
additionalDetails
type_astra_stateDetail
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a user-specified name for the backup. If not specified, or when backups are initiated by a schedule, the system assigns a name for the backup. Defined values are:
bucketID |
string |
True |
JSON string containing an optional bucket ID that indicates where the backup will be stored on create. If not specified, a system-selected bucket is used. If no buckets are available, an error will be returned on create. Defined values are:
snapshotID |
string |
False |
JSON string containing the snapshot that was used to create the backup. To create the backup, a snapshot ID associated with the application being backed up can be specified on create. If not specified, a new snapshot will be created for the backup. Defined values are:
scheduleID |
string |
False |
JSON string containing an optional schedule ID that indicates that the backup was triggered by a schedule and which schedule triggered the backup. Only present for backups initiated by a schedule. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the backup. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why an application backup is unable to transition to "running", or why it has transitioned to "failed" or "removed". Defined values are:
stateDetails |
array[type_astra_stateDetail] |
False |
JSON array of JSON objects which lists additional details about the current state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
hookState |
string |
False |
JSON string containing a value indicating the state of any execution hooks run as part of a snapshot. Defined values are:
hookStateDetails |
False |
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
backupCreationTimestamp |
string |
False |
JSON string containing a timestamp indicating when the backup was taken. Defined values are:
totalBytes |
number |
False |
JSON number containing the total number of bytes in the backup. |
bytesDone |
number |
False |
JSON number containing the number of bytes backed up for a running backup. When the backup is completed, it matches with the totalBytes field. |
percentDone |
number |
False |
JSON number containing the percentage complete for a running backup. When the backup is completed, it is set to "100". |
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
