Retrieve a cloud
Retrieves a cloud resource, providing the stored configuration details for cloud management tasks.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}
Usage notes
Returns the stored Cloud API resource in the JSON response body.
account_id |
string |
path |
True |
cloud_id |
string |
path |
True |
ID of the cloud collection to list |
Status: 200, Returns the stored Cloud API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing the name of the cloud. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the cloud. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why a cloud is unable to transition to "running" or why it has transitioned to "failed". Defined values are:
cloudType |
string |
True |
JSON string containing a value indicating the type of cloud. Defined values are:
credentialID |
string |
False |
JSON string containing a value indicating the ID of the credential that contains the service account for the cloud. This is required for cloudType "gcp", "azure" and "aws". Defined values are:
defaultBucketID |
string |
False |
JSON string containing the ID of a bucket that is to be used by default when creating backups for applications within the cloud. This is required when cloning applications across clusters and is used as a default if a bucket is not specified when creating backups and schedules. Defined values are:
metadata |
True |
"type": "application/astra-cloud",
"version": "1.1",
"id": "1c9512c3-ec62-5ed8-8013-02fc090b9d03",
"name": "GKE",
"state": "discovering",
"stateUnready": [
"Cloud discovery in progress"
"cloudType": "gcp",
"credentialID": "6fa2f917-f730-41b8-9c15-17f531843b31",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
