Retrieve a namespace for a cloud
Retrieves a namespace for a cloud, providing the stored Namespace API resource for cloud operations.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters/{cluster_id}/namespaces/{namespace_id}
Usage notes
Returns the stored Namespace API resource in the JSON response body.
account_id |
string |
path |
True |
cloud_id |
string |
path |
True |
ID of the containing cloud resource |
cluster_id |
string |
path |
True |
ID of the containing cluster resource |
namespace_id |
string |
path |
True |
ID of the namespace collection to list |
Status: 200, Returns the stored Namespace API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
links |
array[type_astra_link] |
True |
Links describing supported operations against the resource. |
name |
string |
True |
JSON string containing a value indicating the name of the namespace. Defined values are:
namespaceState |
string |
True |
JSON string containing a value indicating the state of the namespace. Defined values are:
namespaceStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "state" transitioned into "state a", "state b", or "state c". If no details are available, this array will be empty. Defined values are:
kubernetesLabels |
array[type_astra_label] |
False |
JSON array of JSON objects, each containing a Kubernetes label associated with the namespace. Defined values are:
kubernetesUID |
string |
True |
JSON string containing the Kubernetes generated UID of the namespace resource |
clusterID |
string |
True |
JSON string containing a globally unique identifier of the cluster that the namespace is contained in. Defined values are:
systemType |
string |
False |
JSON string that denotes that the namespace is a type of system namespace. This field identifies what type of system namespace, if any, the namespace is (version 1.1 only). Defined values are:
metadata |
True |
"type": "application/astra-namespace",
"version": "1.2",
"id": "214dc2eb-19a6-5444-b156-f4b6b551a81a",
"links": [
"rel": "canonical",
"href": "/accounts/0b311ae7-d89a-4a11-a52c-1349ca090415/topology/v1/namespaces/7d451d2f-196e-4234-aee9-7e2376047e63",
"type": "application/vnd.netapp.astra.namespace"
"rel": "collection",
"href": "/accounts/0b311ae7-d89a-4a11-a52c-1349ca090415/topology/v1/clouds/e0490197-872e-4de8-9287-b04a938e801f/clusters/0f284377-e5dc-4dcd-bacd-3197f2b8a347/namespaces",
"type": "application/vnd.netapp.astra.namespaces"
"name": "kube-system",
"namespaceState": "discovered",
"namespaceStateDetails": [
"type": "https://astra.netapp.io/stateDetails/9",
"title": "Namespace Discovered",
"detail": "The namespace was discovered in the indicated managed cluster"
"kubernetesLabels": [
"name": "app.kubernetes.io/environment",
"value": "dev"
"clusterID": "0f284377-e5dc-4dcd-bacd-3197f2b8a347",
"kubernetesUID": "4f28c377-e5dc-4dcd-b7cd-319cf2b8a345",
"systemType": "kubernetes",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
targetSchema
accept-post
accept-put
hints
status |
string |
False |
allow |
array[string] |
False |
accept-post |
False |
permissions |
array[string] |
False |
accept-put |
False |
type_astra_link
rel |
string |
True |
href |
string |
True |
type |
string |
False |
targetSchema |
False |
title |
string |
False |
hints |
False |
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
