List the cluster nodes for a managed cluster
Retrieves the cluster nodes for a managed cluster, providing a detailed view of the nodes within the cluster.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/managedClusters/{managedCluster_id}/clusterNodes
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
managedCluster_id |
string |
path |
True |
ID of the containing managedCluster resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: clusterNode_1.0_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-clusterNodes",
"version": "1.0",
"items": [
"test-0",
"e2-medium"
"test-1",
"e2-medium"
"test-2",
"e2-medium"
"test-3",
"e2-micro"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
labels
name |
string |
True |
JSON string containing the label name Defined values are:
value |
string |
True |
JSON string containing the label value Defined values are:
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a value that indicates the Kubernetes name for the node. Defined values are:
role |
string |
True |
JSON string containing a value that indicates the Kubernetes role for the node. Defined values are:
labels |
array[labels] |
True |
JSON array of JSON objects, each containing Kubernetes labels associated with the node. If no details are available, this array will be empty.
creationTime |
string |
True |
JSON string containing an ISO 8601 timestamp that indicates when the node was created. Defined values are:
externalIP |
string |
True |
JSON string containing a value that indicates the internal IP address for the node. Defined values are:
internalIP |
string |
True |
JSON string containing a value that indicates the external IP address for the node. Defined values are:
zone |
string |
True |
JSON string containing a value that indicates the Kubernetes zone for the node. Defined values are:
region |
string |
True |
JSON string containing a value that indicates the Kubernetes region for the node. Defined values are:
instanceType |
string |
True |
JSON string containing a value that indicates the Kubernetes instance type for the node. Defined values are:
kernelVersion |
string |
True |
JSON string containing a value that indicates the kernel version used by the node. Defined values are:
osImage |
string |
True |
JSON string containing a value that indicates the operating system image used by the node. Defined values are:
numCpus |
string |
True |
JSON string containing a value that indicates the number of CPUs assigned to the node. Defined values are:
memory |
string |
True |
JSON string containing a value that indicates the amount of memory assigned to the node. Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the node. Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
