List the namespaces for a managed cluster
Retrieves the namespaces for a managed cluster. Use this to view the namespaces associated with the cluster and manage them effectively.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/managedClusters/{managedCluster_id}/namespaces
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id |
string |
path |
True |
managedCluster_id |
string |
path |
True |
ID of the containing managedCluster resource |
include |
string |
query |
False |
Indicates which fields should be returned when listing a collection. URL examples: "include=id", "include=id,name" OpenAPI examples: "id"
limit |
string |
query |
False |
Indicates the maximum number of resources to return when listing a collection. URL examples: "limit=2" OpenAPI examples: "2" |
filter |
string |
query |
False |
Indicates which fields should be matched in order to return a resource when listing a collection. Supported operators are:
URL example: "filter=field%20eq%20%27value%27" OpenAPI examples: "field eq 'value'" |
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
| Name | Type | Required | Description |
items |
array[Any of: namespace_1.2_get_response_body, array[]] |
True |
metadata |
True |
"type": "application/astra-namespaces",
"version": "1.2",
"items": [
"7d451d2f-196e-4234-aee9-7e2376047e63",
"kube-system",
"name": "app.kubernetes.io/environment",
"value": "dev"
"66b0873b-214f-4ac7-89d8-922432f941eb",
"jenkins",
"value": "dev"
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
targetSchema
accept-post
accept-put
hints
status |
string |
False |
allow |
array[string] |
False |
accept-post |
False |
permissions |
array[string] |
False |
accept-put |
False |
type_astra_link
rel |
string |
True |
href |
string |
True |
type |
string |
False |
targetSchema |
False |
title |
string |
False |
hints |
False |
additionalDetails
type_astra_stateDetail
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
type |
string |
True |
version |
string |
True |
id |
string |
True |
links |
array[type_astra_link] |
True |
Links describing supported operations against the resource. |
name |
string |
True |
JSON string containing a value indicating the name of the namespace. Defined values are:
namespaceState |
string |
True |
JSON string containing a value indicating the state of the namespace. Defined values are:
namespaceStateDetails |
array[type_astra_stateDetail] |
True |
JSON array of JSON objects that lists additional details about why "state" transitioned into "state a", "state b", or "state c". If no details are available, this array will be empty. Defined values are:
kubernetesLabels |
False |
JSON array of JSON objects, each containing a Kubernetes label associated with the namespace. Defined values are:
kubernetesUID |
string |
True |
JSON string containing the Kubernetes generated UID of the namespace resource |
clusterID |
string |
True |
JSON string containing a globally unique identifier of the cluster that the namespace is contained in. Defined values are:
systemType |
string |
False |
JSON string that denotes that the namespace is a type of system namespace. This field identifies what type of system namespace, if any, the namespace is (version 1.1 only). Defined values are:
metadata |
True |
type_astra_metadata_list
continue |
string |
False |
count |
number |
False |
labels |
False |
creationTimestamp |
string |
False |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
