Retrieve a storage class for a managed cluster
Retrieves a storage class for a managed cluster, providing details on the stored configurations for resource management.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/managedClusters/{managedCluster_id}/storageClasses/{storageClass_id}
Usage notes
Returns the stored Storage Class API resource in the JSON response body.
account_id |
string |
path |
True |
managedCluster_id |
string |
path |
True |
ID of the containing managedCluster resource |
storageClass_id |
string |
path |
True |
ID of the storageClass collection to list |
Status: 200, Returns the stored Storage Class API resource in the JSON response body.
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
JSON string containing a value indicating the name of the storage class. Defined values are:
provisioner |
string |
True |
JSON string containing a value indicating the provisioner associated with the storage class. Defined values are:
available |
string |
True |
JSON string indicating whether the storage class is available for the cluster or is eligible to be added to the cluster when under management. Defined values are:
allowVolumeExpansion |
string |
True |
JSON string indicating whether the storage class allows volume expansion. Defined values are:
reclaimPolicy |
string |
True |
JSON string containing a cloud-specific value indicating the retention policy of the storage class. Defined values are:
volumeBindingMode |
string |
True |
JSON string containing a cloud-specific value indicating the binding mode for the storage class. Defined values are:
isDefault |
string |
False |
JSON string indicating whether the storage class contains the default annotation. Defined values are:
maxSnapshotCount |
number |
False |
JSON number indicating how many snapshots are supported. This information is attached to storage classes provided by NetApp. |
maxBackupCount |
number |
False |
JSON number indicating how many backups are supported. This information is attached to storage classes provided by NetApp. |
price |
string |
False |
JSON string indicating the currency units per unit of time for the storage class. This information is attached to storage classes provided by NetApp. Defined values are:
currency |
string |
False |
JSON string indicating the ISO 4217 three-letter code for the currency that the price is measured in. This information is attached to storage classes provided by NetApp. Defined values are:
performance |
number |
False |
JSON number indicating the performance service-level objective (SLO) in MBps. This information is attached to storage classes provided by NetApp. |
resilience |
string |
False |
JSON string indicating the resilience configuration for the storage. This information is attached to storage classes provided by NetApp. Defined values are:
metadata |
True |
"type": "application/astra-storageClass",
"version": "1.1",
"id": "ad9be22b-53c7-540c-8647-76afe2878952",
"name": "my-storage-class",
"provisioner": "csi.trident.netapp.io",
"available": "eligible",
"allowVolumeExpansion": "true",
"reclaimPolicy": "recycle",
"volumeBindingMode": "immediate",
"isDefault": "true",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidParams |
array[invalidParams] |
False |
List of invalid query parameters |
"status": "400"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
