Astra Automation
List all volumes
Retrieves a list of volumes, providing details of each volume in the collection. Use this to view specific fields of interest across all matching volumes.
HTTP method and endpoint
GET /accounts/{account_id}/topology/v1/volumes
Usage notes
Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
account_id
string
path
True
  • example: {{.Account}}
include
string
query
False
Indicates which fields should be returned when listing a collection.
URL examples: "include=id", "include=id,name"
OpenAPI examples: "id"
  • example: id,name
limit
string
query
False
Indicates the maximum number of resources to return when listing a collection.
URL examples: "limit=2"
OpenAPI examples: "2"
Status: 200, Returns a JSON array of all matching resources in the collection. If individual fields are specified in the request, the items JSON array will contain the fields requested for each matching resource in the order specified.
items
array[Any of: volume_1.2_get_response_body, array[]]
True
metadata
type_astra_metadata_list
True
  "type": "application/astra-volumes",
  "version": "1.2",
  "items": [
      "24fe6e79-bf8d-45c9-96af-ef1d11fbd4a0",
      "myVolume"
      "20a370f4-957f-446a-9126-08853d01933a",
      "secondVol"
      "48e349a2-5bcd-4c59-896c-12b8240e634b",
      "smallVol"
  "metadata": {
    "labels": [],
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "401"
Status: 400, Bad request
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
  "status": "403"
Status: 404, Not found
type
string
True
title
string
True
detail
string
True
status
string
True
correlationID
string
False
Example error response
  "status": "404"
additionalDetails
type_astra_stateDetail
type
string
True
title
string
True
detail
string
True
additionalDetails
additionalDetails
False
type_astra_label
name
string
True
value
string
True
type_astra_metadata
  • Conforms to the Astra Metadata Schema
labels
array[type_astra_label]
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
type
string
True
  • "application/astra-volume"
version
string
True
  • "1.0"
  • "1.1"
  • "1.2"
id
string
True
name
string
True
JSON string containing the name of the volume. Defined values are:
  • Minimum length: 1
  • Maximum length: 255
state
string
False
JSON string containing a value indicating the operational state of the volume.
size
string
False
JSON string containing the size of the volume.
used
number
False
JSON number containing the number of bytes of quota used by the provisioned volume.
usedPercentage
number
False
JSON number containing the percentage of volume used.
total
number
False
JSON number containing the total bytes of volumes provisioned.
creationToken
string
False
JSON string containing the creation token of the volume. Defined values are:
  • Minimum length: 1
snapshotPossible
string
False
JSON string indicating whether the driver can perform a snapshot of the volume. Defined values are:
  • "true" - Driver can take a snapshot of the volume
  • "false" - Driver cannot take a snapshot of the volume
storageClass
string
False
JSON string containing the storage class for the volume.
  • Defined values are:
  • Minimum length: 1
pvcName
string
False
JSON string containing the PersistentVolumeClaim (PVC) name of the volume.
  • Minimum length: 1
internalName
string
False
JSON string containing the internal name of the volume on the target storage cluster, if available. This name is obtained from the Kubernetes CSI driver.
  • Minimum length: 1
appsUsing
array[string]
True
JSON array of JSON strings, each containing the ID of an application that is using the volume. Defined values are:
  • Conforms to the Astra Identifier Schema
storageBackendID
string
False
JSON string containing the ID of the storage backend that provides the volume. Defined values are:
orchestrator
string
False
JSON string containing the orchestrator for this volume. This will be defined for Astra Data Store volumes. Defined values are:
  • "trident" - Trident has provisioned this volume
  • "vasa" - NetApp VASA Provider has provisioned this volume
  • "other" - The volume has been provisioned manually or the orchestrator is not known
serviceLevel
string
False
JSON string containing the quality of service (QoS) policy defined for this volume at the storage backend level. This will be defined for Astra Data Store volumes.
exportPolicy
string
False
JSON string containing the export policy associated with this volume. This will be defined for Astra Data Store volumes.
nodeId
string
False
JSON string containing the node ID serving the volume. This will be defined for Astra Data Store volumes. Defined values are:
healthState
string
False
JSON string containing a value indicating the health state of the volume. This will be defined for Astra Data Store volumes. Defined values are:
  • "indeterminate" - The health of the resource cannot be determined (for example, due to lack of connectivity)
  • "normal" - The resource has no known issues and can provide services in accordance with the interface specification
  • "warning" - The resource has known issues that do not prevent it providing services in accordance with the interface specification
  • "critical" - The resource has known issues that prevent it from providing services in accordance with the interface specification
healthStateDetails
array[type_astra_stateDetail]
True
JSON array of JSON objects that lists additional details about the current health. If no details are available, this array will be empty.
  • Minimum Items: 0
metadata
type_astra_metadata
True
continue
string
False
count
number
False
labels
False
creationTimestamp
string
False
string
False
createdBy
string
False
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
