Create a new token for a user in a group
Creates a new token for a user in a group, specifying the desired values to authenticate and authorize group actions.
HTTP method and endpoint
POST /accounts/{account_id}/core/v1/groups/{group_id}/users/{user_id}/tokens
Usage notes
Indicates desired values for the Token API resource to be created.
account_id |
string |
path |
True |
group_id |
string |
path |
True |
ID of the containing group resource |
user_id |
string |
path |
True |
ID of the containing user resource |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
name |
string |
True |
JSON string containing a token name. Defined values are:
metadata |
False |
Example request
"type": "application/astra-token",
"version": "1.0",
"name": "Snapshot Script"
Status: 201, Returns the newly created token resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
userID |
string |
True |
JSON string containing the UUID for the user that the token is associated with. Defined values are:
token |
string |
True |
JSON string containing a base64-encoded system-generated API token. Defined values are:
metadata |
True |
"version": "1.0",
"id": "822fab12-c224-5d1f-8118-5fb5d2def8b9",
"name": "Snapshot Script",
"userID": "09f8933c-ad74-4f4e-8ef5-1ffaa0fb8e9b",
"token": "QSBKV1QgVG9rZW4gd291bGQgZ28gaGVyZS4=",
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
array[invalidFields] |
False |
List of invalid request body fields |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
invalidFields |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata_update
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels. If not specified on update, the metadata object's labels, creationTimestamp and createdBy, will be preserved without modification.
labels |
array[type_astra_label] |
False |
creationTimestamp |
string |
False |
modificationTimestamp |
string |
False |
createdBy |
string |
False |
modifiedBy |
string |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
