Create a new application snapshot for an app
Creates a new application snapshot for an app, capturing the app's current state for backup or recovery purposes.
HTTP method and endpoint
POST /accounts/{account_id}/k8s/v1/apps/{app_id}/appSnaps
Usage notes
Indicates the desired values for the Application Snapshot API resource to be created.
account_id |
string |
path |
True |
app_id |
string |
path |
True |
ID of the containing app resource |
Request Body
| Name | Type | Required | Description |
type |
string |
True |
version |
string |
True |
name |
string |
False |
JSON string containing a user-specified name for the snapshot. If not specified, or when snapshots are initiated by a schedule, the system assigns a name for the snapshot. Defined values are:
bucketID |
string |
False |
JSON string containing an optional bucket ID that indicates where the snapshot will be stored on create. If not specified, a default bucket on the cluster is used. If no default bucket is specified on the cluster, the corresponding cloud default bucket will be used. If the cloud default bucket is not available, an error will be returned on create. Defined values are:
metadata |
False |
Example request
"type": "application/astra-appSnap",
"version": "1.3",
"name": "app-name-245"
Status: 201, Returns the newly created appSnap resource in the JSON response body.
type |
string |
True |
version |
string |
True |
id |
string |
True |
name |
string |
True |
bucketID |
string |
False |
scheduleID |
string |
False |
JSON string containing an optional schedule ID that indicates that the snapshot was triggered by a schedule and specifies which schedule triggered the snapshot. Only present for snapshots initiated by a schedule. Defined values are:
snapshotAppAsset |
string |
False |
JSON string containing the ID of the application asset corresponding to the snapshot. This field will be returned when the state of the application snapshot is "completed". Defined values are:
state |
string |
True |
JSON string containing a value indicating the operational state of the snapshot. Defined values are:
stateUnready |
array[string] |
True |
JSON array of JSON strings, each indicating a reason why an application snapshot is unable to transition to "running", or why it has transitioned to "failed". Defined values are:
stateDetails |
array[type_astra_stateDetail] |
False |
JSON array of JSON objects which lists additional details about the current state, including why the current state was reached. If no details are available, this array will be empty. Defined values are:
hookState |
string |
False |
JSON string containing a value indicating the state of any execution hook or hooks running as a part of a snapshot. Defined values are:
hookStateDetails |
False |
JSON array of JSON objects which lists additional details about why "hookState" transitioned into "failed". If no details are available, this array will be empty.
metadata |
True |
"version": "1.3",
"id": "c2cc5c22-ed0e-5c2b-8b7e-0fb81727f617",
"name": "app-name-245",
"bucketID": "0afbe357-a717-4c7a-8b3d-d0368959c8de",
"scheduleID": "1fe83650-9b3c-41ef-bb25-a2910c19c33e",
"state": "pending",
"stateUnready": [],
"metadata": {
"labels": [],
Status: 401, Unauthorized
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "401"
Status: 400, Bad request
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "400"
Status: 409, Conflict
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "409"
Status: 403, Forbidden
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
"status": "403"
Status: 404, Not found
type |
string |
True |
title |
string |
True |
detail |
string |
True |
status |
string |
True |
correlationID |
string |
False |
Example error response
"status": "404"
type_astra_label
name |
string |
True |
value |
string |
True |
type_astra_metadata
Conforms to the Astra Metadata Schema If not specified on create, a metadata object will be created with no labels.
labels |
array[type_astra_label] |
True |
creationTimestamp |
string |
True |
modificationTimestamp |
string |
True |
createdBy |
string |
True |
modifiedBy |
string |
False |
additionalDetails
type |
string |
True |
title |
string |
True |
detail |
string |
True |
additionalDetails |
False |
invalidParams
name |
string |
True |
Name of the invalid query parameter |
reason |
string |
True |
Reason why the query parameter is invalid |
invalidFields
name |
string |
True |
Name of the invalid request body field |
reason |
string |
True |
Reason why the request body field is invalid |
