Astra Control Center
Uninstall Astra Control Center
Contributors netapp-mwallis
You might need to remove Astra Control Center components if you are upgrading from a trial to a full version of the product. To remove Astra Control Center and the Astra Control Center Operator, run the commands described in this procedure in sequence.
If you have any issues with the uninstall, see Troubleshooting uninstall issues.
Before you begin
  1. Unmanage all apps on the clusters.
  2. Unmanage all clusters.
Steps
  1. Delete Astra Control Center. The following sample command is based upon a default installation. Modify the command if you made custom configurations.
    kubectl delete -f astra_control_center.yaml -n netapp-acc
    Result:
    astracontrolcenter.astra.netapp.io "astra" deleted
  2. Use the following command to delete the netapp-acc (or custom-named) namespace:
    kubectl delete ns [netapp-acc or custom namespace]
    Example result:
    namespace "netapp-acc" deleted
  3. Use the following command to delete Astra Control Center operator system components:
    kubectl delete -f astra_control_center_operator_deploy.yaml
    Result:
    namespace/netapp-acc-operator deleted
    customresourcedefinition.apiextensions.k8s.io/astracontrolcenters.astra.netapp.io deleted
    role.rbac.authorization.k8s.io/acc-operator-leader-election-role deleted
    clusterrole.rbac.authorization.k8s.io/acc-operator-manager-role deleted
    clusterrole.rbac.authorization.k8s.io/acc-operator-metrics-reader deleted
    clusterrole.rbac.authorization.k8s.io/acc-operator-proxy-role deleted
    rolebinding.rbac.authorization.k8s.io/acc-operator-leader-election-rolebinding deleted
    clusterrolebinding.rbac.authorization.k8s.io/acc-operator-manager-rolebinding deleted
    clusterrolebinding.rbac.authorization.k8s.io/acc-operator-proxy-rolebinding deleted
    configmap/acc-operator-manager-config deleted
    service/acc-operator-controller-manager-metrics-service deleted
    deployment.apps/acc-operator-controller-manager deleted
Use the following workarounds to address any problems you have with uninstalling Astra Control Center.
Uninstall of Astra Control Center fails to clean up the monitoring-operator pod on the managed cluster
If you did not unmanage your clusters before you uninstalled Astra Control Center, you can manually delete the pods in the netapp-monitoring namespace and the namespace with the following commands:
Steps
  1. Delete acc-monitoring agent:
    kubectl delete agents acc-monitoring -n netapp-monitoring
    Result:
    agent.monitoring.netapp.com "acc-monitoring" deleted
  2. Delete the namespace:
    kubectl delete ns netapp-monitoring
    Result:
    namespace "netapp-monitoring" deleted
  3. Confirm resources removed:
    kubectl get pods -n netapp-monitoring
    Result:
    No resources found in netapp-monitoring namespace.
  4. Confirm monitoring agent removed:
    kubectl get crd|grep agent
    Sample result:
    agents.monitoring.netapp.com                     2021-07-21T06:08:13Z
  5. Delete custom resource definition (CRD) information:
    kubectl delete crds agents.monitoring.netapp.com
    Result:
    customresourcedefinition.apiextensions.k8s.io "agents.monitoring.netapp.com" deleted
Uninstall of Astra Control Center fails to clean up Traefik CRDs
You can manually delete the Traefik CRDs. CRDs are global resources, and deleting them might impact other applications on the cluster.
Steps
  1. List Traefik CRDs installed on the cluster:
    kubectl get crds |grep -E 'traefik'
    ingressroutes.traefik.containo.us             2021-06-23T23:29:11Z
    ingressroutetcps.traefik.containo.us          2021-06-23T23:29:11Z
    ingressrouteudps.traefik.containo.us          2021-06-23T23:29:12Z
    middlewares.traefik.containo.us               2021-06-23T23:29:12Z
    middlewaretcps.traefik.containo.us            2021-06-23T23:29:12Z
    serverstransports.traefik.containo.us         2021-06-23T23:29:13Z
    tlsoptions.traefik.containo.us                2021-06-23T23:29:13Z
    tlsstores.traefik.containo.us                 2021-06-23T23:29:14Z
    traefikservices.traefik.containo.us           2021-06-23T23:29:15Z
  2. Delete the CRDs:
    kubectl delete crd ingressroutes.traefik.containo.us ingressroutetcps.traefik.containo.us ingressrouteudps.traefik.containo.us middlewares.traefik.containo.us serverstransports.traefik.containo.us tlsoptions.traefik.containo.us tlsstores.traefik.containo.us traefikservices.traefik.containo.us middlewaretcps.traefik.containo.us
Find more information
