Uninstall Astra Control Center
You might need to remove Astra Control Center components if you are upgrading from a trial to a full version of the product. To remove Astra Control Center and the Astra Control Center Operator, run the commands described in this procedure in sequence.
If you have any issues with the uninstall, see Troubleshooting uninstall issues.
Unmanage all apps on the clusters.
Delete Astra Control Center. The following sample command is based upon a default installation. Modify the command if you made custom configurations.
kubectl delete -f astra_control_center.yaml -n netapp-acc
Result:
astracontrolcenter.astra.netapp.io "astra" deleted
Use the following command to delete the
netapp-acc(or custom-named) namespace:kubectl delete ns [netapp-acc or custom namespace]
Example result:
namespace "netapp-acc" deleted
Use the following command to delete Astra Control Center operator system components:
kubectl delete -f astra_control_center_operator_deploy.yaml
Result:
namespace/netapp-acc-operator deleted customresourcedefinition.apiextensions.k8s.io/astracontrolcenters.astra.netapp.io deleted role.rbac.authorization.k8s.io/acc-operator-leader-election-role deleted clusterrole.rbac.authorization.k8s.io/acc-operator-manager-role deleted clusterrole.rbac.authorization.k8s.io/acc-operator-metrics-reader deleted clusterrole.rbac.authorization.k8s.io/acc-operator-proxy-role deleted rolebinding.rbac.authorization.k8s.io/acc-operator-leader-election-rolebinding deleted clusterrolebinding.rbac.authorization.k8s.io/acc-operator-manager-rolebinding deleted clusterrolebinding.rbac.authorization.k8s.io/acc-operator-proxy-rolebinding deleted configmap/acc-operator-manager-config deleted service/acc-operator-controller-manager-metrics-service deleted deployment.apps/acc-operator-controller-manager deleted
Use the following workarounds to address any problems you have with uninstalling Astra Control Center.
Uninstall of Astra Control Center fails to clean up the monitoring-operator pod on the managed cluster
If you did not unmanage your clusters before you uninstalled Astra Control Center, you can manually delete the pods in the netapp-monitoring namespace and the namespace with the following commands:
Delete
acc-monitoringagent:kubectl delete agents acc-monitoring -n netapp-monitoring
Result:
agent.monitoring.netapp.com "acc-monitoring" deleted
Delete the namespace:
kubectl delete ns netapp-monitoring
Result:
namespace "netapp-monitoring" deleted
Confirm resources removed:
kubectl get pods -n netapp-monitoring
Result:
No resources found in netapp-monitoring namespace.
Confirm monitoring agent removed:
kubectl get crd|grep agent
Sample result:
agents.monitoring.netapp.com 2021-07-21T06:08:13Z
Delete custom resource definition (CRD) information:
kubectl delete crds agents.monitoring.netapp.com
Result:
customresourcedefinition.apiextensions.k8s.io "agents.monitoring.netapp.com" deleted
Uninstall of Astra Control Center fails to clean up Traefik CRDs
You can manually delete the Traefik CRDs. CRDs are global resources, and deleting them might impact other applications on the cluster.
List Traefik CRDs installed on the cluster:
kubectl get crds |grep -E 'traefik'
ingressroutes.traefik.containo.us 2021-06-23T23:29:11Z ingressroutetcps.traefik.containo.us 2021-06-23T23:29:11Z ingressrouteudps.traefik.containo.us 2021-06-23T23:29:12Z middlewares.traefik.containo.us 2021-06-23T23:29:12Z middlewaretcps.traefik.containo.us 2021-06-23T23:29:12Z serverstransports.traefik.containo.us 2021-06-23T23:29:13Z tlsoptions.traefik.containo.us 2021-06-23T23:29:13Z tlsstores.traefik.containo.us 2021-06-23T23:29:14Z traefikservices.traefik.containo.us 2021-06-23T23:29:15Z
Delete the CRDs:
kubectl delete crd ingressroutes.traefik.containo.us ingressroutetcps.traefik.containo.us ingressrouteudps.traefik.containo.us middlewares.traefik.containo.us serverstransports.traefik.containo.us tlsoptions.traefik.containo.us tlsstores.traefik.containo.us traefikservices.traefik.containo.us middlewaretcps.traefik.containo.us
