Astra Control Center
Recover volume data using a snapshot
Contributors juliantap netapp-dbagwell
Astra Control Provisioner provides rapid, in-place volume restoration from a snapshot using the TridentActionSnapshotRestore (TASR) CR. This CR functions as an imperative Kubernetes action and does not persist after the operation completes.
Astra Control Provisioner supports snapshot restore on the ontap-san, ontap-san-economy, ontap-nas, ontap-nas-flexgroup, azure-netapp-files, gcp-cvs, and solidfire-san drivers.
Before you begin
You must have a bound PVC and available volume snapshot.
  • Verify the PVC status is bound.
    kubectl get pvc
  • Verify the volume snapshot is ready to use.
    kubectl get vs
Steps
  1. Create the TASR CR. This example creates a CR for PVC pvc1 and volume snapshot pvc1-snapshot.
    cat tasr-pvc1-snapshot.yaml
    kind: TridentActionSnapshotRestore
    metadata:
      namespace: trident
    spec:
      pvcName: pvc1
      volumeSnapshotName: pvc1-snapshot
  2. Apply the CR to restore from the snapshot. This example restores from snapshot pvc1.
    kubectl create -f tasr-pvc1-snapshot.yaml
    tridentactionsnapshotrestore.trident.netapp.io/this-doesnt-matter created
Results
Astra Control Provisioner restores the data from the snapshot. You can verify the snapshot restore status.
kubectl get tasr -o yaml
items:
- apiVersion: trident.netapp.io/v1
  metadata:
    creationTimestamp: "2023-04-14T00:20:33Z"
    generation: 3
    namespace: trident
    resourceVersion: "3453847"
    uid: <uid>
  spec:
    pvcName: pvc1
  status:
    startTime: "2023-04-14T00:20:34Z"
    completionTime: "2023-04-14T00:20:37Z"
    state: Succeeded
kind: List
metadata:
  resourceVersion: ""
Note
  • In most cases, Astra Control Provisioner will not automatically retry the operation in case of failure. You'll need to perform the operation again.
  • Kubernetes users without admin access might have to be granted permission by the admin to create a TASR CR in their application namespace.
