NetApp Backup and Recovery
Back up on-premises ONTAP data to Azure Blob storage with NetApp Backup and Recovery
Contributors netapp-mwallis
Complete a few steps in NetApp Backup and Recovery to get started backing up volume data from your on-premises ONTAP systems to a secondary storage system and to Azure Blob storage.
Note "On-premises ONTAP systems" include FAS, AFF, and ONTAP Select systems.
Note To switch to and from NetApp Backup and Recovery workloads, refer to Switch to different NetApp Backup and Recovery workloads.
Identify the connection method
Choose which of the two connection methods you will use when configuring backups from on-premises ONTAP systems to Azure Blob.
  • Public connection - Directly connect the ONTAP system to Azure Blob storage using a public Azure endpoint.
  • Private connection - Use a VPN or ExpressRoute and route traffic through a VNet Private Endpoint that uses a private IP address.
Optionally, you can connect to a secondary ONTAP system for replicated volumes using the public or private connection as well.
The following diagram shows the public connection method and the connections that you need to prepare between the components. You can use a Console agent that you've installed on your premises, or a Console agent that you've deployed in the Azure VNet.
A diagram showing how NetApp Backup and Recovery communicates over a public connection with the volumes on the cluster and the Azure Blob storage where the backup files are located.
The following diagram shows the private connection method and the connections that you need to prepare between the components. You can use a Console agent that you've installed on your premises, or a Console agent that you've deployed in the Azure VNet.
A diagram showing how NetApp Backup and Recovery communicates over a private connection with the volumes on the cluster and the Azure Blob storage where the backup files are located.
Prepare your Console agent
The Console agent is the main software for NetApp Console functionality. A Console agent is required to back up and restore your ONTAP data.
Create or switch Console agents
If you already have a Console agent deployed in your Azure VNet or on your premises, then you're all set.
If not, then you'll need to create a Console agent in one of those locations to back up ONTAP data to Azure Blob storage. You can't use a Console agent that's deployed in another cloud provider.
Prepare networking for the Console agent
Ensure that the Console agent has the required networking connections.
Steps
  1. Ensure that the network where the Console agent is installed enables the following connections:
    • An HTTPS connection over port 443 to NetApp Backup and Recovery and to your Blob object storage (see the list of endpoints)
    • An HTTPS connection over port 443 to your ONTAP cluster management LIF
    • In order for the NetApp Backup and Recovery Search & Restore functionality to work, port 1433 must be open for communication between the Console agent and the Azure Synapse SQL services.
    • Additional inbound security group rules are required for Azure and Azure Government deployments. See Rules for the Console agent in Azure for details.
  2. Enable a VNet Private Endpoint to Azure storage. This is needed if you have an ExpressRoute or VPN connection from your ONTAP cluster to the VNet and you want communication between the Console agent and Blob storage to stay in your virtual private network (a private connection).
Verify or add permissions to the Console agent
To use the NetApp Backup and Recovery Search & Restore functionality, you need to have specific permissions in the role for the Console agent so that it can access the Azure Synapse Workspace and Data Lake Storage Account. See the permissions below, and follow the steps if you need to modify the policy.
Before you start
You must register the Azure Synapse Analytics Resource Provider (called "Microsoft.Synapse") with your Subscription. See how to register this resource provider for your subscription. You must be the Subscription Owner or Contributor to register the resource provider.
Steps
  1. Identify the role assigned to the Console agent virtual machine:
    1. In the Azure portal, open the Virtual machines service.
    2. Select the Console agent virtual machine.
    3. Under Settings, select Identity.
    4. Select Azure role assignments.
    5. Make note of the custom role assigned to the Console agent virtual machine.
  2. Update the custom role:
    1. In the Azure portal, open your Azure subscription.
    2. Select Access control (IAM) > Roles.
    3. Select the ellipsis (…​) for the custom role and then select Edit.
    4. Select JSON and add the following permissions:
      Details
      "Microsoft.Storage/storageAccounts/listkeys/action",
      "Microsoft.Storage/storageAccounts/read",
      "Microsoft.Storage/storageAccounts/write",
      "Microsoft.Storage/storageAccounts/blobServices/containers/read",
      "Microsoft.Storage/storageAccounts/listAccountSas/action",
      "Microsoft.KeyVault/vaults/read",
      "Microsoft.KeyVault/vaults/accessPolicies/write",
      "Microsoft.Network/networkInterfaces/read",
      "Microsoft.Resources/subscriptions/locations/read",
      "Microsoft.Network/virtualNetworks/read",
      "Microsoft.Network/virtualNetworks/subnets/read",
      "Microsoft.Resources/subscriptions/resourceGroups/read",
      "Microsoft.Resources/subscriptions/resourcegroups/resources/read",
      "Microsoft.Resources/subscriptions/resourceGroups/write",
      "Microsoft.Authorization/locks/*",
      "Microsoft.Network/privateEndpoints/write",
      "Microsoft.Network/privateEndpoints/read",
      "Microsoft.Network/privateDnsZones/virtualNetworkLinks/write",
      "Microsoft.Network/virtualNetworks/join/action",
      "Microsoft.Network/privateDnsZones/A/write",
      "Microsoft.Network/privateDnsZones/read",
      "Microsoft.Network/privateDnsZones/virtualNetworkLinks/read",
      "Microsoft.Network/networkInterfaces/delete",
      "Microsoft.Network/networkSecurityGroups/delete",
      "Microsoft.Resources/deployments/delete",
      "Microsoft.ManagedIdentity/userAssignedIdentities/assign/action",
      "Microsoft.Synapse/workspaces/write",
      "Microsoft.Synapse/workspaces/read",
      "Microsoft.Synapse/workspaces/delete",
      "Microsoft.Synapse/register/action",
      "Microsoft.Synapse/checkNameAvailability/action",
      "Microsoft.Synapse/workspaces/operationStatuses/read",
      "Microsoft.Synapse/workspaces/firewallRules/read",
      "Microsoft.Synapse/workspaces/replaceAllIpFirewallRules/action",
      "Microsoft.Synapse/workspaces/operationResults/read",
      "Microsoft.Synapse/workspaces/privateEndpointConnectionsApproval/action"
    5. Select Review + update and then select Update.
Verify license requirements
You'll need to verify license requirements for both Azure and the Console:
  • Before you can activate NetApp Backup and Recovery for your cluster, you'll need to either subscribe to a pay-as-you-go (PAYGO) Console Marketplace offering from Azure, or purchase and activate a NetApp Backup and Recovery BYOL license from NetApp. These licenses are for your account and can be used across multiple systems.
  • You need to have an Azure subscription for the object storage space where your backups will be located.
Supported regions
You can create backups from on-premises systems to Azure Blob in all regions, including Azure Government regions. You specify the region where the backups will be stored when you set up the service.
Prepare your ONTAP clusters
Prepare your source on-premises ONTAP system and any secondary on-premises ONTAP or Cloud Volumes ONTAP systems.
Preparing your ONTAP clusters involves the following steps:
  • Discover your ONTAP systems in NetApp Console
  • Verify ONTAP system requirements
  • Verify ONTAP networking requirements for backing up data to object storage
  • Verify ONTAP networking requirements for replicating volumes
Both your source on-premises ONTAP system and any secondary on-premises ONTAP or Cloud Volumes ONTAP systems must be available on the NetApp Console Systems page.
You'll need to know the cluster management IP address and the password for the admin user account to add the cluster.
Learn how to discover a cluster.
Make sure your ONTAP system meets the following requirements:
You must configure the following requirements on the system that connects to object storage.
  • For a fan-out backup architecture, configure the following settings on the primary system.
  • For a cascaded backup architecture, configure the following settings on the secondary system.
The following ONTAP cluster networking requirements are needed:
  • The ONTAP cluster initiates an HTTPS connection over port 443 from the intercluster LIF to Azure Blob storage for backup and restore operations.
    ONTAP reads and writes data to and from object storage. The object storage never initiates, it just responds.
  • ONTAP requires an inbound connection from the Console agent to the cluster management LIF. The Console agent can reside in an Azure VNet.
  • An intercluster LIF is required on each ONTAP node that hosts the volumes you want to back up. The LIF must be associated with the IPspace that ONTAP should use to connect to object storage. Learn more about IPspaces.
    When you set up NetApp Backup and Recovery, you are prompted for the IPspace to use. You should choose the IPspace that each LIF is associated with. That might be the "Default" IPspace or a custom IPspace that you created.
  • The nodes' and intercluster LIFs are able to access the object store.
  • DNS servers have been configured for the storage VM where the volumes are located. See how to configure DNS services for the SVM.
  • If you use are using a different IPspace than the Default, then you might need to create a static route to get access to the object storage.
  • Update firewall rules, if necessary, to allow NetApp Backup and Recovery service connections from ONTAP to object storage through port 443 and name resolution traffic from the storage VM to the DNS server over port 53 (TCP/UDP).
If you plan to create replicated volumes on a secondary ONTAP system using NetApp Backup and Recovery, make sure that the source and destination systems meet the following networking requirements.
On-premises ONTAP networking requirements
  • If the cluster is on-premises, you should have a connection from your corporate network to your virtual network in the cloud provider. This is typically a VPN connection.
  • ONTAP clusters must meet additional subnet, port, firewall, and cluster requirements.
    Because you can replicate to Cloud Volumes ONTAP or an on-premises systems, review peering requirements for on-premises ONTAP systems. View prerequisites for cluster peering in the ONTAP documentation.
Cloud Volumes ONTAP networking requirements
  • The instance's security group must include the required inbound and outbound rules: specifically, rules for ICMP and ports 11104 and 11105. These rules are included in the predefined security group.
Prepare Azure Blob as your backup target
  1. You can use your own custom-managed keys for data encryption in the activation wizard instead of using the default Microsoft-managed encryption keys. In this case you will need to have the Azure Subscription, Key Vault name, and the Key. Learn how to use your own keys.
    Note that Backup and recovery supports Azure access policies as the permission model. The Azure role-based access control (Azure RBAC) permission model is not currently supported.
  2. If you want to have a more secure connection over the public internet from your on-prem data center to the VNet, there is an option to configure an Azure Private Endpoint in the activation wizard. In this case you will need to know the VNet and Subnet for this connection. Refer to details about using a Private Endpoint.
Create your Azure Blob storage account
By default, the service creates storage accounts for you. If you want to use your own storage accounts, you can create them before you start the backup activation wizard and then select those storage accounts in the wizard.
Activate backups on your ONTAP volumes
Activate backups at any time directly from your on-premises system.
A wizard takes you through the following major steps:
You can also Show the API commands at the review step, so you can copy the code to automate backup activation for future systems.
Start the wizard
Steps
  1. Access the Activate backup and recovery wizard using one of the following ways:
    • From the Console Systems page, select the system and select Enable > Backup Volumes next to the Backup and recovery service in the right-panel.
      If the Azure destination for your backups exists on the Console Systems page, you can drag the ONTAP cluster onto the Azure Blob object storage.
    • Select Volumes in the Backup and recovery bar. From the Volumes tab, select the Actions Actions icon icon and select Activate Backup for a single volume (that does not already have replication or backup to object storage already enabled).
    The Introduction page of the wizard shows the protection options including local Snapshots, replication, and backups. If you did the second option in this step, the Define Backup Strategy page appears with one volume selected.
  2. Continue with the following options:
    • If you already have a Console agent, you're all set. Just select Next.
    • If you don't already have a Console agent, the Add a Console agent option appears. Refer to Prepare your Console agent.
Select the volumes that you want to back up
Choose the volumes you want to protect. A protected volume is one that has one or more of the following: Snapshot policy, replication policy, backup to object policy.
You can choose to protect FlexVol or FlexGroup volumes; however, you cannot select a mix of these volumes when activating backup for a system. See how to activate backup for additional volumes in the system (FlexVol or FlexGroup) after you have configured backup for the initial volumes.
Note
  • You can activate a backup only on a single FlexGroup volume at a time.
  • The volumes you select must have the same SnapLock setting. All volumes must have SnapLock Enterprise enabled or have SnapLock disabled.
Steps
Note that if the volumes you choose already have Snapshot or replication policies applied, then the policies you select later will overwrite these existing policies.
  1. In the Select Volumes page, select the volume or volumes you want to protect.
    • Optionally, filter the rows to show only volumes with certain volume types, styles, and more to make the selection easier.
    • After you select the first volume, then you can select all FlexVol volumes (FlexGroup volumes can be selected one at a time only). To back up all existing FlexVol volumes, check one volume first and then check the box in the title row.
    • To back up individual volumes, check the box for each volume.
  2. Select Next.
Define the backup strategy
Defining the backup strategy involves setting the following options:
  • Whether you want one or all of the backup options: local Snapshots, replication, and backup to object storage
  • Architecture
  • Local Snapshot policy
  • Replication target and policy
    Note If the volumes you choose have different Snapshot and replication policies than the policies you select in this step, the existing policies will be overwritten.
  • Backup to object storage information (provider, encryption, networking, backup policy, and export options).
Steps
  1. In the Define backup strategy page, choose one or all of the following. All three are selected by default:
    • Local Snapshots: If you are performing replication or back up to object storage, local snapshots must be created.
    • Replication: Creates replicated volumes on another ONTAP storage system.
    • Backup: Backs up volumes to object storage.
  2. Architecture: If you chose replication and backup, choose one of the following flows of information:
    • Cascading: Information flows from the primary to the secondary, and from secondary to object storage.
    • Fan out: Information flows from the primary to the secondary and from the primary to object storage.
      For details about these architectures, refer to Plan your protection journey.
  3. Local Snapshot: Choose an existing snapshot policy or create a new one.
    Tip To create a custom policy before activating the snapshot, refer to Create a policy.
    To create a policy, select Create new policy and do the following:
    • Enter the name of the policy.
    • Select up to five schedules, typically of different frequencies.
    • Select Create.
  4. Replication: Set the following options:
    • Replication target: Select the destination system and SVM. Optionally, select the destination aggregate or aggregates and prefix or suffix that will be added to the replicated volume name.
    • Replication policy: Choose an existing replication policy or create a new one.
      Tip To create a custom policy before activating the replication, refer to Create a policy.
      • Select Create.
  5. Back up to Object: If you selected Backup, set the following options:
    • Provider: Select Microsoft Azure.
    • Provider settings: Enter the provider details and region where the backups will be stored.
      Either create a new storage account or select an existing one.
      Either create your own resource group that manages the Blob container or select the resource group type and group.
      Tip If you want to protect your backup files from being modified or deleted, ensure that the storage account was created with immutable storage enabled using a 30-day retention period.
      Tip If you want to tier older backup files to Azure Archive Storage for further cost optimization, ensure that the storage account has the appropriate Lifecycle rule.
    • Encryption key: If you created a new Azure storage account, enter encryption key information given to you from the provider. Choose whether you'll use the default Azure encryption keys, or choose your own customer-managed keys from your Azure account, to manage encryption of your data.
      If you choose to use your own customer-managed keys, enter the key vault and key information.
    Note If you chose an existing Microsoft storage account, encryption information is already available, so you don't need to enter it now.
    • Networking: Choose the IPspace, and whether you'll be using a Private Endpoint. Private Endpoint is disabled by default.
      1. The IPspace in the ONTAP cluster where the volumes you want to back up reside. The intercluster LIFs for this IPspace must have outbound internet access.
      2. Optionally, choose whether you'll use an Azure private endpoint that you have previously configured. Learn about using an Azure private endpoint.
    • Backup policy: Select an existing Backup to object storage policy or create a new one.
      Tip To create a custom policy before activating the backup, refer to Create a policy.
      • For backup-to-object policies, set the DataLock and Ransomware Resilience settings. For details on DataLock and Ransomware Resilience, refer to Backup-to-object policy settings.
      • Select Create.
    • Export existing snapshots to object storage as backup copies: If there are any local snapshots for volumes in this system that match the backup schedule label you just selected for this system (for example, daily, weekly, etc.), this additional prompt is displayed. Check this box to have all historic Snapshots copied to object storage as backup files to ensure the most complete protection for your volumes.
  6. Select Next.
Review your selections
This is the chance to review your selections and make adjustments, if necessary.
Steps
  1. In the Review page, review your selections.
  2. Optionally check the box to Automatically synchronize the Snapshot policy labels with the replication and backup policy labels. This creates Snapshots with a label that matches the labels in the replication and backup policies.
  3. Select Activate Backup.
Result
NetApp Backup and Recovery starts taking the initial backups of your volumes. The baseline transfer of the replicated volume and the backup file includes a full copy of the primary storage system data. Subsequent transfers contain differential copies of the primary storage system data contained in snapshots.
A replicated volume is created in the destination cluster that will be synchronized with the primary volume.
A Blob storage account is created in the resource group you entered, and the backup files are stored there. The Volume Backup Dashboard is displayed so you can monitor the state of the backups.
You can also monitor the status of backup and restore jobs using the Job Monitoring page.
You might want to display and optionally copy the API commands used in the Activate backup and recovery wizard. You might want to do this to automate backup activation in future systems.
Steps
  1. From the Activate backup and recovery wizard, select View API request.
  2. To copy the commands to the clipboard, select the Copy icon.
