BlueXP classification
Scan data sources overview with BlueXP classification
Contributors netapp-ahibbard amgrissino
BlueXP classification scanns the data in the repositories (the volumes, database schemas, or other user data) that you select to identify personal and sensitive data. BlueXP classification then maps your organizational data, categorizes each file, and identifies predefined patterns in the data. The result of the scan is an index of personal information, sensitive personal information, data categories, and file types.
After the initial scan, BlueXP classification continuously scans your data in a round-robin fashion to detect incremental changes. This is why it's important to keep the instance running.
You can enable and disable scans at the volume level or at the database schema level.
What's the difference between Mapping and Classification scans
You can conduct two types of scans in BlueXP classification:
  • Mapping-only scans provide only a high-level overview of your data and are performed on selected data sources. Mapping-only scans take less time than map and classify scans because the do not access files to see the data inside. You might want to do this initially to identify areas of research and then perform a Map & Classify scan on those areas.
  • Map & Classify scans provide deep-level scanning of your data.
The table below shows some of the differences:
Feature Map & classify scans Mapping-only scans
Scan speed
Slow
Fast
Pricing
Free
Free
Capacity
Limited to 500 TiB*
Limited to 500 TiB*
List of file types and used capacity
Yes
Yes
Number of files and used capacity
Yes
Yes
Age and size of files
Yes
Yes
Ability to run a Data Mapping Report
Yes
Yes
Data Investigation page to view file details
Yes
No
Search for names within files
Yes
No
Create saved searches that provide custom search results
Yes
No
Ability to run other reports
Yes
No
Ability to see metadata from files*
No
Yes
* include::_include/connector-limit.adoc[]
*The following metadata is extracted from files during mapping scans:
  • Working environment
  • Working environment type
  • Storage repository
  • File type
  • Used capacity
  • Number of files
  • File size
  • File creation
  • File last access
  • File last modified
  • File discovered time
  • Permissions extraction
Governance dashboard differences:
Feature Map & Classify Map
Stale data
Yes
Yes
Non-business data
Yes
Yes
Duplicated files
Yes
Yes
Predefined saved searches
Yes
No
Default saved searches
Yes
Yes
DDA report
Yes
Yes
Mapping report
Yes
Yes
Sensitivity level detection
Yes
No
Sensitive data with wide permissions
Yes
No
Open permissions
Yes
Yes
Age of data
Yes
Yes
Size of data
Yes
Yes
Categories
Yes
No
File types
Yes
Yes
Compliance dashboard differences:
Personal information
Yes
No
Sensitive personal information
Yes
No
Privacy risk assessment report
Yes
No
HIPAA report
Yes
No
PCI DSS report
Yes
No
Investigation filters differences:
Saved searches
Yes
Yes
Yes
Yes
Working environment
Yes
Yes
Storage repository
Yes
Yes
File type
Yes
Yes
File size
Yes
Yes
Created time
Yes
Yes
Discovered time
Yes
Yes
Last modified
Yes
Yes
Last access
Yes
Yes
Open permissions
Yes
Yes
File directory path
Yes
Yes
Category
Yes
No
Sensitivity level
Yes
No
Number of identifiers
Yes
No
Personal data
Yes
No
Sensitive personal data
Yes
No
Data subject
Yes
No
Duplicates
Yes
Yes
Classification status
Yes
Status is always "Limited insights"
Scan analysis event
Yes
Yes
File hash
Yes
Yes
Number of users with access
Yes
Yes
User/group permissions
Yes
Yes
File owner
Yes
Yes
Directory type
Yes
Yes
How quickly does BlueXP classification scan data
The scan speed is affected by network latency, disk latency, network bandwidth, environment size, and file distribution sizes.
  • When performing Mapping-only scans, BlueXP classification can scan between 100-150 TiBs of data per day.
  • When performing Map & classify scans, BlueXP classification can scan between 15-40 TiBs of data per day.
