Setting up a data broker group to use an external HashiCorp Vault
When you create a sync relationship that requires Amazon S3, Azure, or Google Cloud credentials, you need to specify those credentials through the BlueXP copy and sync user interface or API. An alternative is to set up the data broker group to access the credentials (or secrets) directly from an external HashiCorp Vault.
This feature is supported through the BlueXP copy and sync API with sync relationships that require Amazon S3, Azure, or Google Cloud credentials.
Prepare the vault to supply credentials to the data broker group by setting up the URLs. The URLs to the secrets in the vault must end with Creds.
Prepare the data broker group to fetch credentials from the external vault by modifying the local config file for each data broker in the group.
Now that everything is set up, you can send an API call to create a sync relationship that uses your vault to get the secrets.
Preparing the vault
You’ll need to provide BlueXP copy and sync with the URL to the secrets in your vault. Prepare the vault by setting up those URLs. You need to set up URLs to the credentials for each source and target in the sync relationships that you plan to create.
The URL must be set up as follows:
/<path>/<requestid>/<endpoint-protocol>Creds
- Path
The prefix path to the secret. This can be any value that’s unique to you.
- Request ID
A request ID that you need to generate. You’ll need to provide the ID in one of the headers in the API POST request when you create the sync relationship.
- Endpoint protocol
One of the following protocols, as defined in the post relationship v2 documentation: S3, AZURE, or GCP (each must be in uppercase).
- Creds
The URL must end with Creds.
The following examples show URLs to secrets.
- Example for the full URL and path for source credentials
http://example.vault.com:8200/my-path/all-secrets/hb312vdasr2/S3Creds
As you can see in the example, the prefix path is /my-path/all-secrets/, the request ID is hb312vdasr2 and the source endpoint is S3.
- Example for the full URL and path for target credentials
http://example.vault.com:8200/my-path/all-secrets/n32hcbnejk2/AZURECreds
The prefix path is /my-path/all-secrets/, the request ID is n32hcbnejk2, and the target endpoint is Azure.
Preparing the data broker group
SSH to a data broker in the group.
Edit the local.json file that resides in /opt/netapp/databroker/config.
Set enable to true and set the config parameter fields under external-integrations.hashicorp as follows:
- enabled
Valid values: true/false
Type: Boolean
Default value: false
True: The data broker gets secrets from your own external HashiCorp Vault
False: The data broker stores credentials in its local vault
- url
Type: string
Value: The URL to your external vault
- path
Type: string
Value: Prefix path to the secret with your credentials
- Reject-unauthorized
Determines if you want the data broker to reject unauthorized external vault
Type: Boolean
Default: false
- auth-method
The authentication method that the data broker should use to access credentials from the external vault
Type: string
Valid values: “aws-iam” / “role-app” / "gcp-iam"
- role-name
Type: string
Your role name (in case you use aws-iam or gcp-iam)
- Secretid & rootid
Type: string (in case you use app-role)
- Namespace
Type: string
Your namespace (X-Vault-Namespace header if needed)
Repeat these steps for any other data brokers in the group.
Example for aws-role authentication
“external-integrations”: {
“hashicorp”: {
“enabled”: true,
“url”: “https://example.vault.com:8200”,
“path”: ““my-path/all-secrets”,
“reject-unauthorized”: false,
“auth-method”: “aws-role”,
“aws-role”: {
“role-name”: “my-role”
Example for gcp-iam authentication
"external-integrations": {
"hashicorp": {
"enabled": true,
"url": http://ip-10-20-30-55.ec2.internal:8200,
"path": "v1/secret",
"namespace": "",
"reject-unauthorized": true,
"auth-method": "gcp-iam",
"aws-iam": {
"role-name": ""
"app-role": {
"root_id": "",
"secret_id": ""
"gcp-iam": {
"role-name": "my-iam-role"
Setting up permissions when using gcp-iam authentication
If you’re using the gcp-iam authentication method, then the data broker must have the following GCP permission:
- iam.serviceAccounts.signJwt
Creating a new sync relationship using secrets from the vault
Post the relationship using the BlueXP copy and sync REST API.
Headers: Authorization: Bearer <user-token> Content-Type: application/json x-account-id: <accountid> x-netapp-external-request-id-src: request ID as part of path for source credentials x-netapp-external-request-id-trg: request ID as part of path for target credentials Body: post relationship v2 body
To obtain a user token and your BlueXP account ID, refer to this page in the documentation.
To build a body for your post relationship, refer to the relationships-v2 API call.
Example
Example for the POST request:
url: https://api.cloudsync.netapp.com/api/relationships-v2
headers:
"x-account-id": "CS-SasdW"
"x-netapp-external-request-id-src": "hb312vdasr2"
"Content-Type": "application/json"
"Authorization": "Bearer eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6Ik…"
Body:
"dataBrokerId": "5e6e111d578dtyuu1555sa60",
"source": {
"protocol": "s3",
"s3": {
"provider": "sgws",
"host": "1.1.1.1",
"port": "443",
"bucket": "my-source"
"target": {
"protocol": "s3",
"s3": {
"bucket": "my-target-bucket"
