Licenses and subscriptions
Manage PAYGO subscriptions and contracts
Contributors netapp-ml94669 netapp-ahibbard joan-ing
When you subscribe to NetApp data services (including Cloud Volumes ONTAP) from a cloud provider's marketplace, you're redirected to the Console website where you save your subscription and associate it with your Console organization. After you subscribe, each subscription is available to manage in the Console.
Note The Marketplace subscriptions page lists all licenses. For license details for a specific data service, use the data service tiles on the Overview dashboard. Learn more about the Overview dashboard.
Required Console role
To perform this task, you need the Licenses and subscriptions admin role.Learn about Licenses and subscriptions roles for NetApp Console.
Add a new marketplace subscription
You can subscribe to a marketplace subscription directly from the Console.
Note For AWS, your account might have more than one NetApp marketplace subscription available, across four offering types: Cloud Volumes ONTAP only (annual contract), Cloud Volumes ONTAP only (PAYGO), NetApp Intelligent Services (annual contract), and NetApp Intelligent Services (PAYGO). If you associate the Cloud Volumes ONTAP only subscription, you can deploy Cloud Volumes ONTAP using Essentials, but configuring Backup and Recovery requires a different subscription. To choose which subscription is used for Cloud Volumes ONTAP capacity billing (including changing billing for existing systems), go to Administration > Licenses and subscriptions > Billing preferences.
Steps
  1. From the NetApp Console menu, select Administration > Licenses and subscriptions.
  2. Select Marketplace subscriptions.
  3. Above the Subscriptions table, select Add subscription.
  4. In the Add subscription dialog, select a cloud provider.
    1. If choosing an AWS subscription, choose the offering you want:
      • Cloud Volumes ONTAP only (annual contract)
      • Cloud Volumes ONTAP only (PAYGO)
      • NetApp Intelligent Services (annual contract)
      • NetApp Intelligent Services (PAYGO)
  5. Select Add subscription to navigate to the provider's marketplace and complete the provided steps.
  6. When finished at the cloud provider marketplace, return to the Console to complete the process.
View your subscriptions
You can view details about each PAYGO subscription and annual contract associated with your Console organization or account.
For Google Cloud, you can also identify marketplace subscriptions associated with a private offer, which enables you to verify that you successfully accepted the offer.
Steps
    You'll only see subscriptions associated with the organization you're currently viewing.
  3. As you view subscription information, you can interact with the table details as follows:
    • Use Advanced Search and Filtering to determine which subscriptions display in the table. You can search by specific subscription name and filter by various subscription parameters such as type and configuration.
    • Expand a row to view more details.
    • Select the plus icon at the end of the table header to choose which columns appear in the table.
      The Term and Auto Renew columns do not appear by default. The Auto Renew column displays renewal information for Azure contracts only.
    Note the following about the table information:
    Start date
    The start date is when you successfully associated the subscription with your account and charging started.
    N/A
    If you see N/A in the table, the information is not currently available from the cloud provider's API.
    Term
    If your Google Cloud subscription is associated with a private offer that was modified after creation and acceptance, the term shows N/A. In this scenario, the API response from Google Cloud Marketplace doesn't include term-related information.
    Contracts
    • When you expand contract details, the Console displays the available contract options and units (capacity or number of nodes) for your current plan.
    • The Console identifies the end date and whether the contract will renew soon, end soon, or has already ended.
    • If you have an AWS contract and changed any contract options after the start date, validate your contract options from the AWS Marketplace.
    • If you have a Google Cloud private offer, contract options aren't available.
Rename a subscription
You can rename a subscription to better identify how your organization uses it.
Steps
  3. Select the action menu in the row that corresponds to the subscription you want to manage and choose Rename.
Configure a subscription with a provider credential
Subscriptions are typically configured with the provider credential you created when you subscribed. In some cases, you may need to reconfigure a subscription to use a different credential to change how it is charged. The credential you associate with a subscription must also be associated with an agent.
The credential format depends on the marketplace you are using. For example, Azure marketplace subscriptions are associated with the Azure subscription name, while AWS marketplace subscriptions use the AWS account ID. You can see a list of available credentials from the Credentials page.
The Configure option is grayed out if you have unsubscribed from a subscription.
Steps
  3. Select the action menu in the row that corresponds to the subscription you want to configure and choose Configure.
  4. In the Configure dialog, choose a credential to configure with the subscription. You can only choose from credentials associated with the currently selected agent. If you don't see the credential you want to use, try switching to a different agent view.
Associate a subscription with a Console organization
Associating a subscription with an organization ensures members of that organization can use that subscription for charging.
You can limit subscription use to a specific organization or share the subscription between multiple organizations.
You must have the organization admin role to associate a subscription with an organization.
Note The Console supports Identity and Access Management (IAM) in standard mode, which uses organizations to manage users and resources. If you're using the Console in private or restricted mode, you use a Console account to manage users and resources, including subscriptions.
Steps
  3. In the row for the subscription you want to associate, open the action menu then select Associate.
  4. In the Associate the subscription dialog, select the Console organizations you want to associate with the subscription.
  5. Select Associate.
View credentials associated with a subscription
You can view the credentials for a specific subscription from the Marketplace subscriptions page. This allows you to verify how the subscription is billed. Because credentials are tied to the agent you're using, you must select the agent associated with the subscription you want to view.
Note Use the Agent drop-down in the top navigation bar to switch agents if needed.
Steps
  3. On the row containing the subscription whose credentials you want to view, select View. If multiple credentials are associated with a subscription, no credentials may display and you are directed to select a different agent.
Remove a subscription
When you unsubscribe from a subscription in your cloud provider (AWS, Google Cloud, or Azure), the Console shows the subscription status as Unsubscribed. When you've unsubscribed from a subscription, you can also remove it from Licenses and subscriptions.
Before you begin
  • You can only remove subscriptions with a status of Unsubscribed. All related settings, data, and configuration must be cleared or reset before removal.
    If the subscription is still configured, the Remove option is not available.
Steps
  1. In the NetApp Console menu, select Administration > Licenses and subscriptions.
  3. In the row for the subscription you want to remove, open the action menu and select Remove.
  4. In the Remove subscription dialog, select Remove to confirm that you want to remove the subscription.
