StorageGRID
Use NetApp data services with StorageGRID
Contributors netapp-bcammett netapp-tonias
After you discover a StorageGRID system in BlueXP, you can use NetApp's data services for backups, data tiering, and data synchronization.
  • Use BlueXP backup and recovery to back up data from your on-premises ONTAP systems to object storage in your NetApp StorageGRID systems.
    To get started, go to the BlueXP canvas and drag and drop an on-premises ONTAP working environment on your StorageGRID working environment.
  • Use BlueXP tiering to automatically tier inactive data from on-premises ONTAP clusters to StorageGRID.
  • Use BlueXP copy and sync to synchronize data to or from a StorageGRID system.
    To get started, go to the BlueXP canvas and drag and drop the source working environment on the target working environment. StorageGRID can be either the source or target.
