Known limitations
Known limitations identify platforms, devices, or functions that are not supported by this release of the product, or that do not interoperate correctly with it. Review these limitations carefully.
Unsupported clusters
On-premises ONTAP clusters that are configured with SAML authentication are not supported with BlueXP.
System Manager limitations
The following System Manager features are not supported from BlueXP:
Cluster setup
After you set the management IP address and configure the admin password on an on-premises ONTAP cluster, you can discover the cluster in BlueXP.
Role-based access control (Connector only)
Role-based access control from System Manager is not supported when discovering and managing an on-prem ONTAP cluster using a Connector. You are prompted to enter your admin credentials during the discovery process. Those credentials are used for all actions taken from System Manager.
With the direct discovery option, you're prompted to log in with your ONTAP credentials each time that you open the working environment.
BlueXP backup and recovery (Cloud Backup) activation
The cluster version must be 9.13.1 to enable BlueXP backup and recovery from System Manager.
If you did not discover a cluster using a Connector, then you can't use System Manager (advanced view) to enable backup and recovery. However, you can enable backup and recovery on an on-premises cluster directly from BlueXP. Learn how to get started
On-demand upgrades
On-demand upgrades of firmware and software are not available if the cluster version is ONTAP 9.9.1 or earlier.
If you do not have a Connector, you cannot make updates from your local machine, only from a server that can be accessed using BlueXP.
Global search
User interface settings
