Discover on-premises ONTAP clusters
Discover on-premises ONTAP clusters from BlueXP so that you can start managing volumes and performing advanced management using ONTAP System Manager, which is available from BlueXP.
Step 1: Review discovery and management options
BlueXP provides two discovery and management options for on-prem ONTAP clusters:
- Discovery and management using a Connector
This option enables you to manage clusters running ONTAP 8.3 and later by using the following features:
The Standard view, which provides basic volume operations
The Advanced view, which provides management through System Manager (supported with ONTAP 9.10.0 and later)
Integration with BlueXP services that provide data replication, back up and recovery, data classification, and data tiering
This option requires a Connector, which you can install in a cloud provider or on your premises.
- Direct discovery and management
This option enables you to manage clusters running ONTAP 9.12.1 and later by using System Manager. No other management options are available. You can't use the Standard view and you can't enable BlueXP services.
This option doesn't require a Connector.
When you access System Manager on an on-premises ONTAP cluster running 9.12.1 or later with connectivity to the BlueXP service, you'll be prompted to manage the cluster directly from BlueXP. If you follow this prompt, it discovers the cluster in BlueXP using the direct discovery option.
Once discovered, your clusters are available as a working environment on the BlueXP Canvas.
If you decide to use the other discovery option at a later time, you will need to discover the on-prem cluster as a separate working environment on the Canvas. You then have the option to remove the other working environment.
Step 2: Set up your environment
Before you discover your on-prem ONTAP clusters, ensure that you've met the following requirements.
- General requirements
You should have gotten started with BlueXP, which includes logging in and setting up an account.
Learn how to get started with BlueXP -
You need the cluster management IP address and the password for the admin user account.
BlueXP discovers ONTAP clusters using HTTPS. If you use custom firewall policies, the ONTAP cluster must allow inbound HTTPS access through port 443.
The default "mgmt" firewall policy allows inbound HTTPS access from all IP addresses. If you modified this default policy, or if you created your own firewall policy, you must associate the HTTPS protocol with that policy and enable access from the Connector host.
- Requirements for Connector discovery
The on-premises cluster must be running ONTAP 8.3 or later.
A Connector must be installed in a cloud provider or on your premises.
If you want to tier cold data to the cloud, then you should review requirements for the Connector based on where you plan to tier cold data.
The Connector host must allow outbound connections through port 443 (HTTPS) and the ONTAP cluster must allow inbound HTTP access through port 443 to the cluster management LIF.
If the Connector is in the cloud, all outbound communication is allowed by the predefined security group.
- Requirements for direct discovery
The on-premises cluster must be running ONTAP 9.12.1 or later.
The cluster must have inbound and outbound connectivity to the BlueXP service:
https://cloudmanager.cloud.netapp.com/ontap-service/check-service-connection
The computer that you're using to access the BlueXP console must have a network connection to the on-prem ONTAP cluster, similar to how you would provide connections to other resources in your private network.
Step 3: Discover a cluster
Discover your on-prem ONTAP clusters from the Canvas in one of two ways:
From Canvas > My Working Environments by manually adding details about the on-premises ONTAP cluster.
From Canvas > My estate by selecting a cluster that BlueXP pre-discovered based on the ONTAP clusters that are associated with the email address for your BlueXP login.
When you start the discovery process, BlueXP discovers a cluster as follows:
If you have an active Connector that has a connection to an ONTAP cluster, then BlueXP will use that Connector to discover and manage the cluster.
If you don't have a Connector or if your Connector doesn't have a connection to the ONTAP cluster, then BlueXP will automatically use the direct discovery and management option.
Discover an on-premises ONTAP cluster in BlueXP by entering the cluster management IP address and the password for the admin user account.
From the navigation menu, select Storage > Canvas.
On the Canvas page, select Add Working Environment > On-Premises.
Next to On-Premises ONTAP, select Discover.
On the Discover page, enter the cluster management IP address, and the password for the admin user account.
If you're discovering the cluster directly (without a Connector), you can select Save the credentials.
If you select this option, you won't need to re-enter the credentials each time that you open the working environment. These credentials are only associated with your BlueXP user login. They aren't saved for use by anyone else in the BlueXP organization.
Select Discover.
If you don't have a Connector and the IP address isn't reachable from BlueXP, then you'll be prompted to create a Connector.
BlueXP discovers the cluster and adds it as a working environment on the Canvas. You can now start managing the cluster.
BlueXP automatically discovers information about the ONTAP clusters that are associated with the email address for your BlueXP login and displays them on the My estate page as undiscovered clusters. You can view the list of undiscovered clusters and add them one at a time.
Note the following about the on-premises ONTAP clusters that appear on the My estate page:
The email address that you use to log in to BlueXP must be associated with a registered, full-level NetApp Support Site (NSS) account.
If you log in to BlueXP with your NSS account and navigate to the My estate page, BlueXP uses that NSS account to find the clusters that are associated with the account.
If you log in to BlueXP with a cloud account or a federated connection and you navigate to the My estate page, BlueXP prompts you to verify your email. If that email address is associated with an NSS account, BlueXP uses that information to find the clusters that are associated with the account.
BlueXP only shows the ONTAP clusters that have successfully sent AutoSupport messages to NetApp.
To refresh the inventory list, exit the My estate page, wait 5 minutes, and then go back to it.
Select My estate.
On the My estate page, select Discover for on-premises ONTAP.
Select a cluster and then select Discover.
Enter the password for the admin user account.
Select Discover.
