NetApp Ransomware Resilience
Protect workloads with NetApp Ransomware Resilience protection strategies
Contributors amgrissino netapp-ahibbard
You can protect workloads against ransomware attacks by enabling workload-consistent protection or creating ransomware protection strategies in NetApp Ransomware Resilience.
Required Console role
To perform this task, you need the Organization admin, Folder or project admin, or Ransomware Resilience admin role. Learn about Ransomware Resilience roles for NetApp Console.
Understand ransomware protection strategies
Ransomware protection strategies encompass detection, protection, and replication policies.
  • Detection policies identify ransomware threats
  • Protection policies include snapshot and backup policies. Detection and snapshot policies are required in a protection strategy. Backup policies are optional.
    If you're using other NetApp products to protect your workload, Ransomware Resilience discovers those and provides the option to either:
    • use a ransomware detection policy and continue to use the snapshot and backup policies created by other NetApp tools, or
    • use Ransomware Resilience to manage detection, snapshots, and backups.
  • Replication policies enable you to replicate snapshots from Ransomware Resilience to a secondary site. Replication schedules can be set to hourly, daily, weekly, or monthly frequencies.
    Currently, you can only replicate snapshots to on-premises ONTAP storage.
Tip For enhanced management and protection of your data estate, you can create group file shares to collectively protect volumes under one strategy.
Protection policies with other NetApp-managed services
Beyond Ransomware Resilience, the following services can be used to manage protection:
  • NetApp Backup and Recovery for file shares, VM file shares
  • SnapCenter for VMware for VM datastores
  • SnapCenter for Oracle
Protection information from these services appears in Ransomware Resilience. You can add detection policies to these services with Ransomware Resilience. Adding a protection policy with Ransomware Resilience replaces the existing protection policies.
If a ransomware detection policy is being managed by Autonomous Ransomware Protection (ARP or ARP/AI, depending on the ONTAP version) and FPolicy in ONTAP, those workloads are protected and will continue to be managed by ARP and FPolicy.
Note Backup destinations are not available for workloads in Amazon FSx for NetApp ONTAP. Perform backup operations using the FSx for ONTAP backup service. You set backup policies for workloads in FSx for ONTAP in AWS, not in Ransomware Resilience. The backup policies appear in Ransomware Resilience and remain unchanged from AWS.
Protection policies for workloads not protected by NetApp applications
If your workload isn't managed by Backup and Recovery, Ransomware Resilience, SnapCenter, or SnapCenter Plug-in for VMware vSphere, it may have snapshots taken as part of ONTAP or other products. If ONTAP FPolicy protection is in place, you can change the FPolicy protection using ONTAP.
View ransomware protection on a workload
One of the first steps in protecting workloads is viewing your current workloads and their protection status. You can see the following types of workloads:
  • Application workloads
  • Block workloads
  • File share workloads
  • VM workloads
Steps
  1. From the Console's left navigation, select Protection > Ransomware Resilience.
  2. Do one of the following:
    • From the Data Protection pane on the Dashboard, select View all.
    • From the menu, select Protection.
      Protection page
  3. From this page, you can view and change protection details for the workload.
Note See Add a ransomware protection strategy to learn about using Ransomware Resilience when there's an existing protection policy with SnapCenter or Backup and Recovery.
Understand the Protection page
The Protection page shows the following information about workload protection:
Protection status: A workload can show one of the following protection statuses to indicate whether a policy is applied or not:
  • Protected: A policy is applied. ARP (or ARP/AI depending on the ONTAP version) is enabled on all volumes related to the workload.
  • At risk: No policy is applied. If a workload does not have a primary detection policy enabled, it is "at risk" even if it has a snapshot and backup policy enabled.
  • In progress: A policy is being applied but not completed yet.
  • Failed: A policy is applied but is not working.
Detection status: A workload can have one of the following ransomware detection statuses:
  • Learning: A ransomware detection policy was recently assigned to the workload and Ransomware Resilience is scanning workloads.
  • Active: A ransomware detection protection policy is assigned.
  • Not set: A ransomware detection protection policy is not assigned.
  • Error: A ransomware detection policy was assigned, but Ransomware Resilience has encountered an error.
    Tip When protection is enabled in Ransomware Resilience, alert detection and reporting begins after the ransomware detection policy status changes from Learning mode to Active mode.
Note Suspicious user behavior activity and FPolicy (suspicious file extension) activity are listed separately from detection status.
Detection policy: The name of the ransomware detection policy appears, if one has been assigned. If the detection policy has not been assigned, "N/A" appears.
Replication destination: If you've configured snapshot replication, the names of the destination storage VMs and systems are listed. If there's no replication, this field displays "None."
Snapshot and backup policies: This column shows the snapshot and backup policies applied to the workload and the product or service that is managing those policies.
  • Managed by SnapCenter
  • Managed by SnapCenter Plug-in for VMware vSphere
  • Managed by Backup and Recovery
  • Name of ransomware protection policy that governs snapshots and backups
  • None
Workload importance
Ransomware Resilience assigns an importance or priority to each workload during discovery based on an analysis of each workload. The workload importance is determined by the following snapshot frequencies:
  • Critical: More than one snapshot copy is taken per hour (highly aggressive protection schedule)
  • Important: Snapshots copies are created less frequently than every hour but more frequently than every day
  • Standard: Snapshot copies are taken more than once per day
Predefined detection policies
You can choose one of the following Ransomware Resilience predefined policies, which are aligned with workload importance.
Note The Encryption user extension policy is the only predefined policy that supports suspicious user behavior detection.
The Critical replication policy is the only predefined policy that supports replicating snapshots to ONTAP.
Policy level Snapshot Frequency Retention (days) Number of snapshot copies Maximum number of snapshot copies
Critical workload policy
Quarter hourly
Every 15 min
3
288
309
Daily
Every 1 day
14
14
309
Weekly
Every 1 week
35
5
309
Monthly
Every 30 days
60
2
309
Important workload policy
Quarter hourly
Every 30 mins
3
144
165
Daily
Every 1 day
14
14
165
Weekly
Every 1 week
35
5
165
Monthly
Every 30 days
60
2
165
Standard workload policy
Quarter hourly
Every 30 min
3
72
93
Daily
Every 1 day
14
14
93
Weekly
Every 1 week
35
5
93
Monthly
Every 30 days
60
2
93
Quarter hourly
Every 30 min
3
72
93
Daily
Every 1 day
14
14
93
Weekly
Every 1 week
35
5
93
Monthly
Every 30 days
60
2
93
Quarter hourly
Every 30 min
3
72
93
Daily
Every 1 day
14
14
93
Weekly
Every 1 week
35
5
93
Monthly
Every 30 days
60
2
93
Quarter hourly
Every 15 min
3
288
309
Daily
Every 1 day
14
14
309
Weekly
Every 1 week
35
5
309
Monthly
Every 30 days
60
2
309
Enable application- or VM-consistent protection with SnapCenter
Enabling application- or VM-consistent protection helps you protect your application or VM workloads in a consistent manner, achieving a quiescent and consistent state to avoid potential data loss later if recovery is needed.
This process initiates registering SnapCenter Software Server for applications or SnapCenter Plug-in for VMware vSphere for VMs using Backup and Recovery.
After you enable workload-consistent protection, you can manage protection strategies in Ransomware Resilience. The protection strategy includes the snapshot and backup policies managed elsewhere along with a ransomware detection policy managed in Ransomware Resilience.
To learn about registering SnapCenter or SnapCenter Plug-in for VMware vSphere using Backup and Recovery, refer to the following information:
Steps
  1. From the Ransomware Resilience menu, select Dashboard.
  2. From the Recommendations pane, locate one of the following recommendations and select Review and fix:
    • Register available SnapCenter Server with the NetApp Console
    • Register available SnapCenter Plug-in for VMware vSphere (SCV) with the NetApp Console
  3. Follow the information to register the SnapCenter or SnapCenter Plug-in for VMware vSphere host using Backup and Recovery.
  4. Return to Ransomware Resilience.
  5. From Ransomware Resilience, navigate to the Dashboard and initiate the discovery process again.
  6. From Ransomware Resilience, select Protection to view the Protection page.
  7. Review details in the snapshot and backup policies column on the Protection page to see that the policies are managed elsewhere.
There are three approaches to adding a ransomware protection strategy:
  • Create a ransomware protection strategy if you have no snapshot or backup policies.
    The ransomware protection strategy includes:
    • Snapshot policy
    • Ransomware detection policy
    • Backup policy
  • Replace the existing snapshot or backup policies from SnapCenter or Backup and Recovery protection with protection strategies managed by Ransomware Resilience.
    • Snapshot policy
    • Backup policy
  • Create a detection policy for workloads with existing snapshot and backup policies managed in other NetApp products or services.
    The detection policy does not change the policies managed in other products.
    The detection policy enables Autonomous Ransomware Protection and FPolicy protection if they are already activated in other services. Learn more about Autonomous Ransomware Protection, Backup and Recovery, and ONTAP FPolicy.
Create a ransomware protection strategy (if you have no snapshot or backup policies)
If snapshot or backup policies do not exist on the workload, you can create a ransomware protection strategy, which can include the following policies that you create in Ransomware Resilience:
  • Snapshot policy
  • Backup policy
  • Secondary replication to ONTAP
Steps to create a ransomware protection strategy
  1. From the Ransomware Resilience menu, select Protection.
    Manage strategy page
  2. From the Protection page, select a workload then Protect.
  3. From the Ransomware protection strategies page, select Add.
    Add strategy page showing the snapshot section
  4. Enter a new strategy name, or enter an existing name to copy it. If you enter an existing name, choose which one to copy and select Copy.
    Note If you choose to copy and modify an existing strategy, Ransomware Resilience appends "_copy" to the original name. You should change the name and at least one setting to make it unique.
  5. For each item, select the Down arrow.
    • Detection policy:
      • Policy: Choose one of the predesigned detection policies.
      • Primary detection: Enable Ransomware Resilience to detect potential ransomware attacks.
      • Suspicious user behavior detection: Enable user behavior detection to transmit user activity events to Ransomware Resilience and detect suspicious events, such as data breaches.
      • Block file extensions: Enable Ransomware Resilience to block known suspicious file extensions. Ransomware Resilience takes automated snapshot copies when Primary detection is enabled.
        If you want to change the blocked file extensions, edit them in System Manager.
    • Snapshot policy:
      • Snapshot policy base name: Select a policy or select Create and enter a name for the snapshot policy.
      • Snapshot locking: Enable this to lock the snapshot copies on primary storage so that they cannot be modified or deleted for a certain period of time even if a ransomware attack manages its way to the backup storage destination. This is also called immutable storage. This enables quicker restore time.
        When a snapshot is locked, the volume expiration time is set to the expiration time of the snapshot copy.
        Snapshot copy locking is available with ONTAP 9.12.1 and later. To learn more about SnapLock, refer to SnapLock in ONTAP.
      • Snapshot schedules: Choose schedule options, the number of snapshot copies to keep, and select to enable the schedule.
    • Replication policy:
      • Replication policy basename: Enter a new name or choose an existing one. The basename is the prefix appended to all snapshots.
      • Replication schedules: Toggle the frequencies you want to enable (hourly, daily, weekly, or monthly) and set the retention value (the number of replicated snapshots to keep) for each schedule you enable.
    • Backup policy:
      • Backup policy basename: Enter a new or choose an existing name.
      • Backup schedules: Choose schedule options for secondary storage and enable the schedule.
        Tip To enable backup locking on secondary storage, configure your backup destinations using the Settings option. For details, see Configure settings.
  6. Select Add.
Add a detection policy to workloads with existing snapshot and backup policies managed by SnapCenter or Backup and Recovery
Ransomware Resilience enables you to assign either a detection policy or a protection policy to workloads with existing snapshot and backup protection managed in other NetApp products or services. Other services, such as Backup and Recovery and SnapCenter, use policies that govern snapshots, replication to secondary storage, or backups to object storage.
Add a detection policy to workloads with existing backup or snapshot policies
If you have existing snapshot or backup policies with Backup and Recovery or SnapCenter, you can add a policy to detect ransomware attacks. To manage protection and detection with Ransomware Resilience, see Protect with Ransomware Resilience.
Steps
  2. From the Protection page, select a workload then select Protect.
  3. Ransomware Resilience detects if there are existing active SnapCenter or Backup and Recovery policies.
  4. To leave your existing Backup and Recovery or SnapCenter policies in place and only apply a detection policy, leave the Replace existing policies box unchecked.
  5. To see details of the SnapCenter policies, select the Down arrow.
  6. Select the detection settings you want:
    Encryption detection
    Block suspicious file extensions
  7. Select Next.
  8. If you selected Suspicious user behavior detection as a detection setting, select the User activity agent or or create one.
    The user activity agent hosts the new data collectors. Ransomware Resilience creates the data collector automatically to transmit user activity events to Ransomware Resilience to detect anomalous user behavior.
  9. Select Next.
  10. Review your choices. Select Create to activate detection.
  11. On the Protection page, review the Detection status to confirm detection is Active.
Replace existing backup or snapshot policies with a ransomware protection strategy
You can replace your existing backup or snapshot policies with a ransomware protection strategy. This approach removes your externally managed protection and configures detection and protection in Ransomware Resilience.
Steps
  3. Ransomware Resilience detects if there are existing active Backup and Recovery or SnapCenter policies. To replace the existing Backup and Recovery or SnapCenter policies, select the Replace existing policies box. When you select the box, Ransomware Resilience replaces the list of detection policies with detection policies.
  4. Choose a protection policy. If no protection policy exists, select Add to create a new policy. For information about creating a policy, see Create a protection policy. Select Next.
  5. If your strategy includes replication, select the Destination system and Destination storage VM. Select Next.
  6. Select a backup destination or create a new one. Select Next.
    1. If your protection strategy includes user behavior detection, select a User activity agent in your environment to host the new data collectors. Ransomware Resilience creates the data collector automatically to transmit user activity events to Ransomware Resilience to detect anomalous user behavior.
  7. Review the new protection strategy then select Protect to apply it.
  8. On the Protection page, review the Detection status to confirm detection is Active.
Assign a different policy
You can replace the existing policy with a different one.
Steps
  2. From the Protection page, on the workload row, select Edit protection.
  3. If the workload has an existing Backup and Recovery or SnapCenter policy that you want to maintain, uncheck Replace existing policies. To replace the existing policies, check Replace existing policies.
  4. In the Policies page, select the down arrow for the policy you want to assign to review the details.
  5. Select the policy you want to assign.
  6. Select Protect to complete the change.
Create a protection group
Grouping file shares in a protection group makes it easier to protect your data estate. Ransomware Resilience can protect all volumes in a group at the same time rather than protecting each volume separately.
You can create groups regardless of their protection status (that is, groups not protected and groups that are protected). When you add a protection policy to a protection group, the new protection policy replaces any existing policy, including policies managed by SnapCenter and NetApp Backup and Recovery.
Steps
  2. From the Protection page, select the Protection groups tab.
    Protection groups page
  3. Select Add.
    Add protection group page
  4. Enter a name for the protection group.
  5. Select the workloads to add to the group.
    Tip To see more details on the workloads, scroll to the right.
  6. Select Next.
    Add protection group - Policy page
  7. Select the policy to govern the protection for this group. To confirm, select Next.
  8. If the protection strategy includes replication, review the replication settings.
    1. To replicate all snapshots to the same destination, check Use same destination for each workload. Choose a Destination system and Destination storage VM for the workloads under the Console agent section. + To use different destinations, uncheck that box. Review each workloads under each Console agent and assign a Destination system and Destination storage VM for each workload. Select Next.
  9. To configure a backup policy, choose one then select Next.
  10. If your detection policy includes user behavior detection, select the data collector you want to use then Next.
  11. Review the selections for the protection group.
  12. To finalize creation of the protection group, select Add.
Edit group protection
You can change the detection policy on an existing group.
Steps
  2. From the Protection page, select the Protection groups tab then select the group whose policy you want to modify.
  3. From protection group's overview page, select Edit protection.
  4. Select an existing protection policy to apply or select Add to create a new protection policy. For more information about adding a protection policy see, Create a protection policy. Then select Save.
  5. In the backup destination overview, select an existing backup destination or Add a new backup destination.
  6. Select Next to review your changes.
Remove workloads from a group
You might later need to remove workloads from an existing group.
Steps
  3. Select the group from which you want to remove one or more workloads.
    Protection group details page
  4. From the selected protection group page, select the workload you want to remove from the group and select the Actions Actions button option.
  5. From the Actions menu, select Remove workload.
  6. Confirm that you want to remove the workload and select Remove.
Delete the protection group
Deleting the protection group removes the group and its protection but doesn't remove the individual workloads.
Steps
  4. From the selected protection group page, at the top right, select Delete protection group.
  5. Confirm that you want to delete the group and select Delete.
Manage ransomware protection strategies
You can delete a ransomware strategy.
View workloads protected by a ransomware protection strategy
Before you delete a ransomware protection strategy, you might want to view which workloads are protected by that strategy.
You can view the workloads from the list of strategies or when you are editing a specific strategy.
Steps to view strategies
  2. From the Protection page, select Manage protection strategies.
    The Ransomware protection strategies page displays a list of strategies.
    Ransomware protection strategies screen showing a list of strategies
  3. On the Ransomware protection strategies page in the Protected workloads column, select the down arrow at the end of the row.
Delete a ransomware protection strategy
You can delete a protection strategy that is not currently associated with any workloads.
Steps
  3. In the Manage strategies page, select the Actions Actions button option for the strategy you want to delete.
  4. From the Actions menu, select Delete policy.
