Storage limits in Azure
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering. NetApp doesn't support exceeding this limit.
| License | Maximum system capacity (disks + object storage) |
Freemium |
500 GiB |
PAYGO Explore |
2 TiB (data tiering is not supported with Explore) |
PAYGO Standard |
10 TiB |
PAYGO Premium |
368 TiB |
Node-based license |
2 PiB (requires multiple licenses) |
Capacity-based license |
2 PiB |
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
Disk and tiering limits by VM size
The disk limits below are specific to disks that contain user data. The limits do not include the root disk, core disk, and VNVRAM.
The number of data disks listed in the tables below are as 9.7 P5. In previous 9.7 releases, two additional data disks were supported. Starting in 9.7 P5, Cloud Volumes ONTAP uses an additional disk for core data and another for VNVRAM. This change reduced the number of disks available for data. |
The tables below show the maximum system capacity by VM size with disks alone, and with disks and cold data tiering to object storage.
Single node systems can use Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks, with up to 32 TiB per disk. The number of supported disks varies by VM size.
HA systems use Premium page blobs as disks, with up to 8 TiB per page blob. The number of supported disks varies by VM size.
You can purchase multiple node-based licenses for a Cloud Volumes ONTAP BYOL single node or HA pair system to allocate more than 368 TiB of capacity, up to the maximum tested and supported system capacity limit of 2 PiB. Be aware that disk limits can prevent you from reaching the capacity limit by using disks alone. You can go beyond the disk limit by tiering inactive data to object storage. Learn how to add additional system licenses to Cloud Volumes ONTAP. Though Cloud Volumes ONTAP supports up to the maximum tested and supported system capacity of 2 PiB, crossing the 2 PiB limit results in an unsupported system configuration. |
Single node with a Premium license
| VM size | Max data disks per node | Max system capacity with disks alone | Max system capacity with disks and data tiering |
DS5_v2 |
61 |
368 TiB |
368 TiB |
DS14_v2 |
61 |
368 TiB |
368 TiB |
DS15_v2 |
61 |
368 TiB |
368 TiB |
E32s_v3 |
29 |
368 TiB |
368 TiB |
E48s_v3 |
29 |
368 TiB |
368 TiB |
L8s_v2 |
13 |
368 TiB |
368 TiB |
Single node with node-based licensing
For some VM types, you'll need several BYOL licenses to reach the max system capacity listed below. For example, you'd need 6 BYOL licenses to reach 2 PiB with DS5_v2. |
| VM size | Max data disks per node | Max system capacity with one license | Max system capacity with multiple licenses | ||
Disks alone |
Disks + data tiering |
Disks alone |
DS3_v2 |
13 |
368 TiB |
368 TiB |
416 TiB |
2 PiB |
DS4_v2 |
29 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
DS5_v2 |
61 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
DS13_v2 |
29 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
DS14_v2 |
61 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
DS15_v2 |
61 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
E32s_v3 |
29 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
E48s_v3 |
29 |
368 TiB |
368 TiB |
896 TiB |
2 PiB |
L8s_v2 |
13 |
368 TiB |
368 TiB |
416 TiB |
2 PiB |
Single node with capacity-based licensing
DS3_v2 |
13 |
416 TiB |
2 PiB |
DS4_v2 |
29 |
896 TiB |
2 PiB |
DS5_v2 |
61 |
896 TiB |
2 PiB |
DS13_v2 |
29 |
896 TiB |
2 PiB |
DS14_v2 |
61 |
896 TiB |
2 PiB |
DS15_v2 |
61 |
896 TiB |
2 PiB |
E32s_v3 |
29 |
896 TiB |
2 PiB |
E48s_v3 |
29 |
896 TiB |
2 PiB |
L8s_v2 |
13 |
416 TiB |
2 PiB |
HA pairs with a Premium license
| VM size | Max data disks for an HA pair | Max system capacity with disks alone | Max system capacity with disks and data tiering |
DS5_v2 |
61 |
368 TiB |
368 TiB |
DS14_v2 |
61 |
368 TiB |
368 TiB |
DS15_v2 |
61 |
368 TiB |
368 TiB |
HA pairs with node-based licensing
| VM size | Max data disks for an HA pair | Max system capacity with one license | Max system capacity with multiple licenses | ||
Disks alone |
Disks alone |
DS4_v2 |
29 |
232 TiB |
368 TiB |
232 TiB |
2 PiB |
DS5_v2 |
61 |
368 TiB |
368 TiB |
488 TiB |
2 PiB |
DS13_v2 |
29 |
232 TiB |
368 TiB |
232 TiB |
2 PiB |
DS14_v2 |
61 |
368 TiB |
368 TiB |
488 TiB |
2 PiB |
DS15_v2 |
61 |
368 TiB |
368 TiB |
488 TiB |
2 PiB |
HA pairs with capacity-based licensing
DS5_v2 |
61 |
488 TB |
2 PiB |
DS14_v2 |
61 |
488 TB |
2 PiB |
DS15_v2 |
61 |
488 TB |
2 PiB |
Aggregate limits
Cloud Volumes ONTAP uses Azure storage as disks and groups them into aggregates. Aggregates provide storage to volumes.
| Parameter | Limit |
Maximum number of aggregates |
Same as the disk limit |
Maximum aggregate size 1 |
384 TiB of raw capacity for single node 2 |
Disks per aggregate |
1-12 3 |
Maximum number of RAID groups per aggregate |
1 |
Notes:
The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
If using node-based licensing, two BYOL licenses are required to reach 384 TiB.
All disks in an aggregate must be the same size.
Logical storage limits
| Logical storage | Parameter | Limit |
Storage virtual machines (SVMs) |
Maximum number for Cloud Volumes ONTAP |
One data-serving SVM and one destination SVM used for disaster recovery. You can activate the destination SVM for data access if there’s an outage on the source SVM. 1 |
Files |
Maximum size |
16 TiB |
Maximum per volume |
Volume size dependent, up to 2 billion |
FlexClone volumes |
Hierarchical clone depth 2 |
499 |
FlexVol volumes |
Maximum per node |
500 |
Minimum size |
20 MB |
Maximum size |
100 TiB |
Qtrees |
Maximum per FlexVol volume |
4,995 |
Snapshot copies |
1,023 |
Notes:
Cloud Manager does not provide any setup or orchestration support for SVM disaster recovery. It also does not support storage-related tasks on an additional SVM. You must use System Manager or the CLI for SVM disaster recovery.
Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
iSCSI storage limits
| iSCSI storage | Parameter | Limit |
LUNs |
Maximum per node |
1,024 |
Maximum number of LUN maps |
1,024 |
Maximum size |
16 TiB |
512 |
igroups |
Maximum per node |
256 |
Initiators |
Maximum per node |
512 |
Maximum per igroup |
128 |
iSCSI sessions |
Maximum per node |
1,024 |
LIFs |
Maximum per port |
32 |
Maximum per portset |
32 |
Portsets |
Maximum per node |
256 |
