Cloud Volumes ONTAP
Known limitations in AWS
Contributors netapp-bcammett
The following known limitations are specific to Cloud Volumes ONTAP in Amazon Web Services. Be sure to also review Limitations in all cloud providers.
AWS Outpost limitations
If you have an AWS Outpost, you can deploy Cloud Volumes ONTAP in that Outpost by selecting the Outpost VPC in the Working Environment wizard. The experience is the same as any other VPC that resides in AWS. Note that you will need to first deploy a Connector in your AWS Outpost.
There are a few limitations to point out:
  • Only single node Cloud Volumes ONTAP systems are supported at this time
  • The EC2 instances that you can use with Cloud Volumes ONTAP are limited to what's available in your Outpost
  • Only General Purpose SSDs (gp2) are supported at this time
Flash Cache limitations
C5D and R5D instance types include local NVMe storage, which Cloud Volumes ONTAP uses as Flash Cache. Note the following limitations:
  • Compression must be disabled on all volumes to take advantage of the Flash Cache performance improvements.
    You can choose no storage efficiency when creating a volume from BlueXP, or you can create a volume and then disable data compression by using the CLI.
  • Cache rewarming after a reboot is not supported with Cloud Volumes ONTAP.
False alarms reported by Amazon CloudWatch
Cloud Volumes ONTAP does not release CPUs when idle, so Amazon CloudWatch can report a high CPU warning for the EC2 instance because it sees 100% usage. You can ignore this alarm. The ONTAP statistics command displays the true usage of the CPUs.
Cloud Volumes ONTAP HA pairs do not support immediate storage giveback
After a node reboots, the partner must sync data before it can return the storage. The time that it takes to resync data depends on the amount of data written by clients while the node was down and the data write speed during the time of giveback.
