Known limitations for Cloud Volumes ONTAP 9.6 in Azure
Contributors netapp-bcammett
The following known limitations are specific to Cloud Volumes ONTAP in Microsoft Azure. Be sure to also review Limitations for Cloud Volumes ONTAP 9.6 in all cloud providers.
New deployments aren’t supported
New deployments of Cloud Volumes ONTAP 9.6 are no longer supported in Azure. You’ll need to deploy Cloud Volumes ONTAP 9.7.
HA limitations
The following limitations affect Cloud Volumes ONTAP HA pairs in Microsoft Azure:
Pay-as-you-go not available for CSP partners
If you are a Microsoft Cloud Solution Provider (CSP) partner, you cannot deploy Cloud Volumes ONTAP Explore, Standard, or Premium because pay-as-you-go subscriptions are not available for CSP partners. You must purchase a license and deploy Cloud Volumes ONTAP BYOL.
