Storage limits for Cloud Volumes ONTAP 9.10.0 in Azure
Contributors netapp-bcammett
Cloud Volumes ONTAP has storage configuration limits to provide reliable operations. For best performance, do not configure your system at the maximum values.
Maximum system capacity by license
The maximum system capacity for a Cloud Volumes ONTAP system is determined by its license. The maximum system capacity includes disk-based storage plus object storage used for data tiering.
NetApp doesn’t support exceeding the system capacity limit. If you reach the licensed capacity limit, Cloud Manager displays an action required message and no longer allows you to add additional disks.
License Maximum system capacity (disks + object storage)
Freemium
500 GiB
PAYGO Explore
2 TiB (data tiering is not supported with Explore)
PAYGO Standard
10 TiB
PAYGO Premium
368 TiB
Node-based license
368 TiB per license
Capacity-based license
2 PiB
For HA, is the license capacity limit per node or for the entire HA pair?
The capacity limit is for the entire HA pair. It is not per node. For example, if you use the Premium license, you can have up to 368 TiB of capacity between both nodes.
Disk and tiering limits by VM size
The disk limits below are specific to disks that contain user data. The limits do not include the root disk, core disk, and VNVRAM.
The tables below show the maximum system capacity by VM size with disks alone, and with disks and cold data tiering to object storage.
  • Single node systems can use Standard HDD Managed Disks, Standard SSD Managed Disks, and Premium SSD Managed Disks, with up to 32 TiB per disk. The number of supported disks varies by VM size.
  • HA systems use Premium page blobs as disks, with up to 8 TiB per page blob. The number of supported disks varies by VM size.
Note You can purchase multiple node-based licenses for a Cloud Volumes ONTAP BYOL system to allocate more than 368 TiB of capacity. The number of licenses that you can purchase for a single node system or HA pair is unlimited. Be aware that disk limits can prevent you from reaching the capacity limit by using disks alone. You can go beyond the disk limit by tiering inactive data to object storage. Learn how to add additional system licenses to Cloud Volumes ONTAP.
Single node with a Premium license
VM size Max data disks per node Max system capacity with disks alone Max system capacity with disks and data tiering
DS5_v2
61
368 TiB
368 TiB
DS14_v2
61
368 TiB
368 TiB
DS15_v2
61
368 TiB
368 TiB
E32s_v3
29
368 TiB
368 TiB
E48s_v3
29
368 TiB
368 TiB
E64is_v3
29
368 TiB
368 TiB
Single node with node-based licensing
Note For some VM types, you’ll need several BYOL licenses to reach the max system capacity listed below. For example, you’d need 6 BYOL licenses to reach 1.95 PiB with DS5_v2.
VM size Max data disks per node Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks + data tiering
Disks alone
DS4_v2
29
368 TiB
368 TiB
928 TiB
368 TiB x each license
DS5_v2
61
368 TiB
368 TiB
1.95 PiB
DS13_v2
29
368 TiB
368 TiB
928 TiB
DS14_v2
61
368 TiB
368 TiB
1.95 PiB
DS15_v2
61
368 TiB
368 TiB
1.95 PiB
E4s_v3
5
160 TiB
368 TiB
160 TiB
E8s_v3
13
368 TiB
368 TiB
416 TiB
E32s_v3
29
368 TiB
368 TiB
928 TiB
E48s_v3
29
368 TiB
368 TiB
928 TiB
E64is_v3
29
368 TiB
368 TiB
928 TiB
L8s_v2
13
368 TiB
368 TiB
416 TiB
Single node with capacity-based licensing
DS4_v2
29
928 TiB
2 PiB
DS5_v2
61
1.95 PiB
2 PiB
DS13_v2
29
928 TiB
2 PiB
DS14_v2
61
1.95 PiB
2 PiB
DS15_v2
61
1.95 PiB
2 PiB
E4s_v3
5
160 TiB
2 PiB
E8s_v3
13
416 TiB
2 PiB
E32s_v3
29
928 TiB
2 PiB
E48s_v3
29
928 TiB
2 PiB
E64is_v3
29
928 TiB
2 PiB
L8s_v2
13
416 TiB
2 PiB
HA pairs with a Premium license
VM size Max data disks for an HA pair Max system capacity with disks alone Max system capacity with disks and data tiering
DS5_v2
61
368 TiB
368 TiB
DS14_v2
61
368 TiB
368 TiB
DS15_v2
61
368 TiB
368 TiB
E8s_v3
13
104 TiB
368 TiB
E48s_v3
29
232 TiB
368 TiB
E80ids_v4
29
232 TiB
368 TiB
HA pairs with node-based licensing
VM size Max data disks for an HA pair Max system capacity with one license Max system capacity with multiple licenses
Disks alone
Disks alone
DS4_v2
29
232 TiB
368 TiB
232 TiB
DS5_v2
61
368 TiB
368 TiB
488 TiB
DS13_v2
29
232 TiB
368 TiB
232 TiB
DS14_v2
61
368 TiB
368 TiB
488 TiB
DS15_v2
61
368 TiB
368 TiB
488 TiB
E8s_v3
13
104 TiB
368 TiB
104 TiB
E48s_v3
29
232 TiB
368 TiB
232 TiB
E80ids_v4
29
232 TiB
368 TiB
232 TiB
HA pairs with capacity-based licensing
DS4_v2
29
232 TiB
2 PiB
DS5_v2
61
488 TiB
2 PiB
DS13_v2
29
232 TiB
2 PiB
DS14_v2
61
488 TiB
2 PiB
DS15_v2
61
488 TiB
2 PiB
E8s_v3
13
104 TiB
2 PiB
E48s_v3
29
232 TiB
2 PiB
E80ids_v4
29
232 TiB
2 PiB
Aggregate limits
Cloud Volumes ONTAP uses Azure storage as disks and groups them into aggregates. Aggregates provide storage to volumes.
Parameter Limit
Maximum number of aggregates
Same as the disk limit
Maximum aggregate size 1
384 TiB of raw capacity for single node 2
352 TiB of raw capacity for single node with PAYGO
96 TiB of raw capacity for HA pairs
Disks per aggregate
1-12 3
Maximum number of RAID groups per aggregate
1
Notes:
  1. The aggregate capacity limit is based on the disks that comprise the aggregate. The limit does not include object storage used for data tiering.
  2. If using node-based licensing, two BYOL licenses are required to reach 384 TiB.
  3. All disks in an aggregate must be the same size.
Storage VM limits
Some configurations enable you to create additional storage VMs (SVMs) for Cloud Volumes ONTAP.
These are the tested limits. While it is theoretically possible to configure additional storage VMs, it’s not supported.
License type Storage VM limit
PAYGO
  • 1 storage VM for serving data
  • 1 storage VM for disaster recovery
Freemium
24 storage VMs total 1,2
Capacity-based license 3
Node-based BYOL 4
  1. These 24 storage VMs can serve data or be configured for disaster recovery (DR).
  2. Each storage VM can have up to three LIFs where two are data LIFs and one is an SVM management LIF.
  3. For capacity-based licensing, there are no extra licensing costs for additional storage VMs, but there is a 4 TiB minimum capacity charge per storage VM. For example, if you create two storage VMs and each has 2 TiB of provisioned capacity, you’ll be charged a total of 8 TiB.
  4. For node-based BYOL, an add-on license is required for each additional data-serving storage VM beyond the first storage VM that comes with Cloud Volumes ONTAP by default. Contact your account team to obtain a storage VM add-on license.
    Storage VMs that you configure for disaster recovery (DR) don’t require an add-on license (they are free of charge), but they do count against the storage VM limit. For example, if you have 12 data-serving storage VMs and 12 storage VMs configured for disaster recovery, then you’ve reached the limit and can’t create any additional storage VMs.
File and volume limits
Logical storage Parameter Limit
Files
Maximum size
16 TiB
Maximum per volume
Volume size dependent, up to 2 billion
FlexClone volumes
Hierarchical clone depth 2
499
FlexVol volumes
Maximum per node
500
Minimum size
20 MB
Maximum size
100 TiB
Qtrees
Maximum per FlexVol volume
4,995
Snapshot copies
1,023
Notes:
  1. Cloud Manager does not provide any setup or orchestration support for SVM disaster recovery. It also does not support storage-related tasks on an additional SVM. You must use System Manager or the CLI for SVM disaster recovery.
  2. Hierarchical clone depth is the maximum depth of a nested hierarchy of FlexClone volumes that can be created from a single FlexVol volume.
iSCSI storage limits
iSCSI storage Parameter Limit
LUNs
Maximum per node
1,024
Maximum number of LUN maps
1,024
Maximum size
16 TiB
Maximum per volume
512
igroups
Maximum per node
256
Initiators
Maximum per node
512
Maximum per igroup
128
iSCSI sessions
Maximum per node
1,024
LIFs
Maximum per port
32
Maximum per portset
32
Portsets
Maximum per node
256
