Before Installing or Upgrading the NetApp Kubernetes Monitoring Operator
Read this information before installing or upgrading the Kubernetes Monitoring Operator.
Component | Requirement |
Kubernetes version |
Kubernetes v1.20 and above. |
Kubernetes distributions |
AWS Elastic Kubernetes Service (EKS) |
Linux OS |
Cloud Insights does not support nodes that are running with Arm64 architecture. |
Labels |
Cloud Insights supports monitoring of Kubernetes nodes that are running Linux, by specifying a Kubernetes node selector that looks for the following Kubernetes labels on these platforms: |
Commands |
The curl and kubectl commands must be available.; for best results, add these commands to the PATH. |
Connectivity |
kubectl cli is configured to communicate with the target K8s cluster, and have Internet connectivity to your Cloud Insights environment. |
Other |
If you are running on OpenShift 4.6 or higher, you must follow the OpenShift Instructions in addition to ensuring these pre-requisites are met. |
API Token |
If you are re-deploying the Operator (i.e. you are updating or replacing it), there is no need to create a new API token; you can re-use the previous token. |
Important Things to Note Before You Start
If you are running with a proxy, have a custom repository, or are using OpenShift, read the following sections carefully.
Also read about Permissions.
Configuring Proxy Support
There are two places where you may use a proxy in your environment in order to install the NetApp Kubernetes Monitoring Operator. These may be the same or separate proxy systems:
Proxy needed during execution of the installation code snippet (using "curl") to connect the system where the snippet is executed to your Cloud Insights environment
Proxy needed by the target Kubernetes cluster to communicate with your Cloud Insights environment
If you use a proxy for either or both of these, to install the NetApp Kubernetes Operating Monitor you must first ensure that your proxy is configured to allow good communication to your Cloud Insights environment. For example, from the servers/VMs from which you wish to install the Operator, you need to be able to access Cloud Insights and be able to download binaries from Cloud Insights.
For the proxy used to install the NetApp Kubernetes Operating Monitor, before installing the Operator, set the http_proxy/https_proxy environment variables. For some proxy environments, you may also need to set the no_proxy environment variable.
To set the variable(s), perform the following steps on your system before installing the NetApp Kubernetes Monitoring Operator:
Set the https_proxy and/or http_proxy environment variable(s) for the current user:
If the proxy being setup does not have Authentication (username/password), run the following command:
export https_proxy=<proxy_server>:<proxy_port>
If the proxy being setup does have Authentication (username/password), run this command:
export http_proxy=<proxy_username>:<proxy_password>@<proxy_server>:<proxy_port>
For the proxy used for your Kubernetes cluster to communicate with your Cloud Insights environment, install the NetApp Kubernetes Monitoring Operator after reading all of these instructions.
Configure the proxy section of AgentConfiguration in operator-config.yaml before deploying the NetApp Kubernetes Monitoring Operator.
agent: ... proxy: server: <server for proxy> port: <port for proxy> username: <username for proxy> password: <password for proxy> # In the noproxy section, enter a comma-separated list of # IP addresses and/or resolvable hostnames that should bypass # the proxy noproxy: <comma separated list> isTelegrafProxyEnabled: true isFluentbitProxyEnabled: <true or false> # true if Events Log enabled isCollectorsProxyEnabled: <true or false> # true if Network Performance and Map enabled isAuProxyEnabled: <true or false> # true if AU enabled ... ...
Using a custom or private docker repository
By default, the NetApp Kubernetes Monitoring Operator will pull container images from the Cloud Insights repository. If you have a Kubernetes cluster used as the target for monitoring, and that cluster is configured to only pull container images from a custom or private Docker repository or container registry, you must configure access to the containers needed by the NetApp Kubernetes Monitoring Operator.
Run the “Image Pull Snippet” from the NetApp Monitoring Operator install tile. This command will log into the Cloud Insights repository, pull all image dependencies for the operator, and log out of the Cloud Insights repository. When prompted, enter the provided repository temporary password. This command downloads all images used by the operator, including for optional features. See below for which features these images are used for.
Core Operator Functionality and Kubernetes Monitoring
netapp-monitoring
kube-rbac-proxy
kube-state-metrics
telegraf
distroless-root-user
Events Log
fluent-bit
kubernetes-event-exporter
ci-net-observer
Push the operator docker image to your private/local/enterprise docker repository according to your corporate policies. Ensure that the image tags and directory paths to these images in your repository are consistent with those in the Cloud Insights repository.
Edit the monitoring-operator deployment in operator-deployment.yaml, and modify all image references to use your private Docker repository.
image: <docker repo of the enterprise/corp docker repo>/kube-rbac-proxy:<kube-rbac-proxy version> image: <docker repo of the enterprise/corp docker repo>/netapp-monitoring:<version>
Edit the AgentConfiguration in operator-config.yaml to reflect the new docker repo location. Create a new imagePullSecret for your private repository, for more details see https://kubernetes.io/docs/tasks/configure-pod-container/pull-image-private-registry/
agent: ... # An optional docker registry where you want docker images to be pulled from as compared to CI's docker registry # Please see documentation for link:task_config_telegraf_agent_k8s.html#using-a-custom-or-private-docker-repository[using a custom or private docker repository]. dockerRepo: your.docker.repo/long/path/to/test # Optional: A docker image pull secret that maybe needed for your private docker registry dockerImagePullSecret: docker-secret-name
If you are running on OpenShift 4.6 or higher, you must edit the AgentConfiguration in operator-config.yaml to enable the runPrivileged setting:
# Set runPrivileged to true SELinux is enabled on your kubernetes nodes runPrivileged: true
Openshift may implement an added level of security that may block access to some Kubernetes components.
Permissions
If the cluster you are monitoring contains Custom Resources which do not have a ClusterRole which aggregates to view, you will need to manually grant the operator access to these resources to monitor them with Event Logs.
Edit operator-additional-permissions.yaml before installing, or after installing edit the resource ClusterRole/<namespace>-additional-permissions
Create a new rule for the desired apiGroups and resources with the verbs ["get", "watch", "list"]. See https://kubernetes.io/docs/reference/access-authn-authz/rbac/
Apply your changes to the cluster
