Learn about NetApp Console local deployment
NetApp Console local deployment lets you host and run the NetApp Console autonomous control plane in your own infrastructure.
You get unified storage management, policy enforcement, fleet-scale automation, and AI-assisted operations. No data, metadata, or management traffic leaves your environment.
Deploy and operate Console in your own infrastructure
NetApp Console local deployment runs in your own infrastructure, so your team controls deployment, connectivity, and daily operations. This gives enterprise administrators full control of operational boundaries while keeping management data inside the environment.
Automate storage operations with APIs and service accounts
NetApp Console local deployment supports API-based integrations so your organization can automate repeatable storage operations. Service accounts let applications authenticate and operate with assigned roles. The same role-based access control and audit controls that apply to interactive users govern those actions. This supports enterprise automation while keeping access scoped and accountable.
Control access with RBAC and Active Directory integration
NetApp Console local deployment provides zero-trust role-based access control (RBAC) that limits what users can see and do within the fleets and resources they manage. You can integrate with Active Directory so users sign in with their existing corporate credentials, and local users can add multi-factor authentication (MFA) for another layer of verification. Access governance stays aligned with your organization's broader identity and access management practices.
Organize fleets and delegate storage administration
NetApp Console local deployment scales administration by organizing resources into folders and fleets. You can map fleets to environments, business units, or regions, then delegate administration at organization, folder, or fleet scope to keep ownership clear. This structure helps large storage teams distribute work without losing policy consistency or governance.
Track and export administrative activity for compliance
Every administrative action generates an audit record. Security and compliance teams can use these records to investigate incidents, show control effectiveness, and satisfy audit requirements. Export audit logs to your syslog server through a webhook for centralized monitoring, longer retention, and analysis. Because NetApp Console local deployment runs in your own environment, log data never leaves your infrastructure.
Provision storage consistently with storage class policies
NetApp Console local deployment enforces consistent storage behavior through storage classes—templates that bundle performance, capacity, and tiering policies into reusable definitions. Administrators define storage standards once. Administrators and automated workflows use those approved classes for all provisioning activity across your environment. This stops configuration drift, reduces the time junior administrators spend on provisioning decisions, and guarantees that every workload meets your organization's standards immediately. After provisioning, Console local deployment continues to monitor each workload for compliance.
Monitor storage class compliance and remediate drift automatically
NetApp Console local deployment monitors every workload against the storage class used to provision it. When a workload drifts—because of a direct cluster configuration change or degrading performance—NetApp Console local deployment flags the violation immediately. Administrators can follow guided remediation steps or configure automated remediation to resolve common drift conditions without manual intervention. This continuous enforcement reduces audit risk and keeps your environment compliant between scheduled reviews.
Monitor storage health and receive alerts across fleets
NetApp Console local deployment gives you a single place to watch the health and performance of every cluster you manage. Fleet-wide dashboards display clusters and volumes that need attention. Custom dashboards let administrators build monitoring views that match their responsibilities. The Workload Analyzer correlates latency, throughput, resource utilization, and configuration changes over time to help you pinpoint root causes before issues affect workloads.
Configure email and webhook delivery channels so alerts reach the right teams when conditions change. Organization admins set up destinations, and storage admins apply them in alert rules so response paths match your operational model. This helps enterprise teams respond faster to capacity, performance, and protection events.
Provision storage and investigate alerts with natural language
NetApp Console local deployment can connect to your own large language model (LLM) to provide AI-assisted storage management. You can describe a workload in plain language to get a provisioning plan, ask the Console to investigate an active alert, or get contextual answers about your storage environment. Every AI action stays within the guardrails of your storage classes and the role-based access controls that apply to your account, and you must confirm sensitive operations before they proceed. Console local deployment sends requests only to the LLM endpoint your administrators configure.
Back up and restore storage with NetApp Backup and Recovery
Beyond provisioning and monitoring, NetApp Console local deployment gives you access to NetApp Backup and Recovery so you can protect your data from the same interface. You can back up and restore your data to support your protection and recovery requirements. Managing data protection alongside your storage keeps governance consistent and reduces the number of tools your teams need to operate.
