NetApp Console local deployment
Build dashboards for monitoring goals in NetApp Console local deployment
Contributors netapp-tonias netapp-ml94669
Create a custom dashboard in NetApp Console local deployment, add cards, and save a monitoring view for daily operations.
If you only need organization-level monitoring that is ready to use, start with predefined Home page dashboards. Create a custom dashboard when you need a role-specific view, resource-level targeting, or a tailored card layout.
Console local deployment dashboard guidelines
  • Only the user who creates the dashboard can view it. You cannot share dashboards with other users, even when you add them to the Console Home page.
  • You can only view resources that you have permission to view. If you do not see a resource in the list of available resources, you do not have permission to view it.
  • Before you begin, identify the metric types and resources you want the dashboard to track. Learn about custom dashboard cards and metrics in NetApp Console local deployment
Build a dashboard for your monitoring goals
Create a dashboard when you need one place to monitor the metrics that matter to your role, such as fleet health, performance hotspots, and alert trends.
Steps
  1. Select Storage > Dashboards.
  2. Select Add Dashboard.
    Console local deployment creates a new dashboard with a default name and no description.
  3. Select Add Card.
  4. Select the Resource type for the card, such as fleet, system, or volume and then choose resources from the list of available resources.
  5. Select Next to continue to choose a metric and card type.
  6. Choose a metric to display. You can filter the available metrics by type: the Metric Type: Performance, Capacity, Health, or Alerts or search for a specific metric by name. The available metrics depend on the resource type you selected.
  7. Select a card to include in the dashboard and select Next.
    You can only select one card at a time. The card preview shows live data for the selected metric and resource type.
  8. Name your card. The name must be unique within the dashboard.
  9. Review the card preview, enter a card name and description, and then select Add.
  10. Repeat these steps for additional cards.
  11. Select the pencil icon to edit the dashboard name and description to describe its purpose.
  12. Select the action menu to the right of the Add card button and select Save dashboard.
    The saved dashboard is available under Storage > Dashboards.
  13. Optionally, add this dashboard to your Home page by selecting Add to Home page from the action menu. The dashboard is added to the Home page. Only you can view custom dashboards that you create. It is not shared with others.
