NetApp Console setup and administration
Learn about NetApp Console
Contributors netapp-tonias
NetApp Console offers a SaaS experience for full feature access or a self-hosted option for organizations with connectivity restrictions.
You can use NetApp Console in two ways: as a fully managed SaaS experience or as a self-hosted solution in your own cloud environment. With the SaaS option, you access the Console through console.netapp.com while NetApp manages all infrastructure, authentication, and updates. You get complete feature access directly from your web browser. If you choose the self-hosted option, you install a Console agent in your AWS, Azure, or Google Cloud environment. The interface runs locally, and the agent maintains limited outbound connectivity to NetApp for essential tasks like authentication and updates.
Choose the SaaS experience if your organization has standard internet connectivity. You benefit from the simplest setup, automatic updates, and full access to all NetApp storage systems, data services, and advanced features. You can add agents directly from the Console, and NetApp handles all maintenance.
Select the self-hosted option if your organization requires strict connectivity, security, or compliance controls, such as in government or regulated industries. You gain more control and network isolation, but you can only manage select NetApp storage systems and use limited data services, with some features unavailable. You install a Console agent manually and access the Console directly from the local agent interface. Install your agent through your cloud marketplace or manual installation, and the agent communicates outbound-only to NetApp, ensuring no inbound internet connections.
Overview
Each deployment mode differs in outbound connectivity, location, installation, authentication, data services, and charging methods.
Standard mode
You use a SaaS service from the web-based console. Depending on the data services and features that you plan to use, a Console organization admin creates one or more Console agents to manage data within your hybrid cloud environment.
This mode uses encrypted data transmission over the public internet.
Restricted mode
You install a Console agent in the cloud (in a government, sovereign, or commercial region), and it has limited outbound connectivity to the NetApp Console SaaS layer.
This mode is typically used by state and local governments and regulated companies.
BlueXP private mode (legacy BlueXP interface only)
BlueXP private mode (legacy BlueXP interface) is typically used with on-premises environments that have no internet connection and with secure cloud regions, which includes AWS Secret Cloud, AWS Top Secret Cloud, and Azure IL6. NetApp continues to support these environments with the legacy BlueXP interface. PDF documentation for BlueXP private mode
The following table provides a comparison of the NetApp console.
Standard mode Restricted mode
Connection required to NetApp Console SaaS layer?
Yes
Outbound only
Connection required to your cloud provider?
Yes
Yes, within the region
Console agent installation
From the Console, cloud marketplace, or manual install
Cloud marketplace or manual install
Console agent upgrades
Automatic upgrades
Automatic upgrades
UI access
From the Console SaaS layer
Locally from an agent VM
API endpoint
The Console SaaS layer
A Console agent
Authentication
Through SaaS using auth0, NSS login, or identity federation
Through SaaS using auth0 or identity federation
Multi-factor authentication
Available for local users
Not available
Storage and data services
All are supported
Many are supported
Data service licensing options
Marketplace subscriptions and BYOL
Read through the following sections to learn more about these modes, including which NetApp Console features and services are supported.
Standard mode
The following image is an example of a standard mode deployment.
A conceptual image that shows the architecture of standard mode with the public internet where the SaaS layer and auth0 authentication are available.
The Console works as follows in standard mode:
Outbound communication
Connectivity is required from a Console agent to the Console SaaS layer, to your cloud provider's publicly available resources, and to other essential components for day-to-day operations.
Supported location for an agent
In standard mode, an agent is supported in the cloud or on your premises.
You can install an agent using one of the following methods:
  • From the Console
  • From the AWS or Azure Marketplace
  • From the Google Cloud SDK
  • Manually using an installer on a Linux host in your data center or cloud
  • Use the provided OVA in your VCenter environment.
NetApp automatically upgrades your agent monthly.p.
User interface access
The user interface is accessible from the web-based console that's provided through the SaaS layer.
API endpoint
API calls are made to the following endpoint:
https://api.bluexp.netapp.com
Authentication
Authentication with auth0 or NetApp Support Site (NSS) logins. Identity federation is available.
Supported data services
All NetApp data services are supported. Learn more about NetApp data services.
Supported licensing options
Marketplace subscriptions and BYOL are supported with standard mode; however, the supported licensing options depends on which NetApp data service you are using. Review the documentation for each service to learn more about the available licensing options.
How to get started with standard mode
Go to the NetApp Console and sign up.
Restricted mode
The following image is an example of a restricted mode deployment.
A conceptual image of restricted mode.
The Console works as follows in restricted mode:
An agent requires outbound connectivity to the Console SaaS layer for data services, software upgrades, authentication, and metadata transmission.
The Console SaaS layer does not initiate communication to an agent. Agents initiate all communication with the Console SaaS layer, pulling or pushing data as needed.
A connection is also required to cloud provider resources from within the region.
In restricted mode, an agent is supported in the cloud: in a government region, sovereign region, or commercial region.
You can install from the AWS or Azure Marketplace or a manual installation on your own Linux host or us a downloadable OVA in your VCenter environment.
NetApp automatically upgrades your agent software with monthly updates.
The user interface is accessible from an agent virtual machine that's deployed in your cloud region.
API endpoint
API calls are made to the agent virtual machine.
Authentication
Authentication is provided through auth0. Identity federation is also available.
Supported storage management and data services
The following storage and data services with restricted mode:
Supported services Notes
Azure NetApp Files
Full support
Backup and recovery
Supported in Government regions and commercial regions with restricted mode. Not supported in sovereign regions with restricted mode.
In restricted mode, NetApp Backup and Recovery supports back up and restore of ONTAP volume data only. View the list of supported backup destinations for ONTAP data
Back up and restore of application data and virtual machine data is not supported.
NetApp Data Classification
Supported in Government regions with restricted mode. Not supported in commercial regions or in sovereign regions with restricted mode.
Cloud Volumes ONTAP
Full support
Licenses and subscriptions
You can access license and subscription information with the supported licensing options listed below for restricted mode.
On-premises ONTAP clusters
Discovery with a Console agent and discovery without a Console agent (direct discovery) are both supported.
When you discover an on-premises cluster without a Console agent, the Advanced view (System Manager) is not supported.
Replication
The following licensing options are supported with restricted mode:
  • Marketplace subscriptions (hourly and annual contracts)
    Note the following:
    • For Cloud Volumes ONTAP, only capacity-based licensing is supported.
    • In Azure, annual contracts are not supported with government regions.
  • BYOL
    For Cloud Volumes ONTAP, both capacity-based licensing and node-based licensing are supported with BYOL.
How to get started with restricted mode
You need to enable restricted mode when you create your NetApp Console organization.
If you don't have an organization yet, you are prompted to create your organization and enable restricted mode when you log in to the Console for the first time from a Console agent that you manually installed or that you created from your cloud provider's marketplace.
Note You cannot change the restricted mode setting after creating the organization.
Service and feature comparison
The following table can help you quickly identify which services and features are supported with restricted mode.
Note that some services might be supported with limitations. For more details about how these services are supported with restricted mode, refer to the sections above.
Product area NetApp data service or feature Restricted mode
Storage
This portion of the table lists support for storage systems management from the Console. It does not indicate the supported backup destinations for NetApp Backup and Recovery.
Amazon FSx for ONTAP
No
Amazon S3
No
Azure Blob
No
Azure NetApp Files
Yes
Cloud Volumes ONTAP
Yes
Google Cloud NetApp Volumes
No
Google Cloud Storage
No
Yes
E-Series
No
StorageGRID
No
Data Services
NetApp Backup and recovery
Yes
View the list of supported backup destinations for ONTAP volume data
Yes
NetApp Copy and Sync
No
NetApp Disaster Recovery
No
NetApp Ransomware Resilience
No
NetApp Replication
Yes
NetApp Cloud Tiering
No
NetApp Volume caching
No
NetApp Workload factory
No
Features
Alerts
No
Digital Advisor
No
License and subscription management
Yes
Identity and access management
Yes
Credentials
Yes
Federation
Yes
Lifecycle planning
No
Yes
NSS accounts
Yes
Notifications
Yes
Search
Yes
Software updates
No
Sustainability
No
Audit
Yes
