Maintain NetApp Console agent VMs
Keep your Console agent VMs patched, correctly sized, and healthy so that the agent stays operational at all times.
Apply operating system updates to agent hosts
Apply security updates to the operating system and associated packages on your agent host so that the host stays secure.
This is your responsibility as the customer. The Console agent software can upgrade itself, but it does not upgrade the operating system or associated packages.
If you deployed the Console agent in vCenter using an OVA, the operating system is part of the agent image. Upgrade the agent using an ISO to update the operating system. |
Follow your company's standard procedures for your operating system distribution. You don't need to stop agent host services when you apply OS security patches.
On agents that you did not deploy from an OVA, prevent Docker or Podman from being upgraded during routine OS patching to maintain compatibility with supported configurations. You can do this by either temporarily excluding Docker or Podman during updates or by permanently configuring the package manager to skip Docker or Podman updates.
The following are examples of how to exclude Docker or Podman updates for different Linux distributions. Consult your Linux distribution's documentation for the most up-to-date instructions on how to exclude packages from updates.
sudo yum update --exclude=podman
sudo yum upgrade
sudo apt-mark hold docker-ce docker-ce-cli containerd.io
sudo apt update
sudo apt upgrade
Resize the VM or instance type
Increase the CPU or RAM of an under-provisioned agent VM so that the agent keeps performing well.
If you create a Console agent from the Console, it deploys a VM instance in your cloud provider with a default configuration. Learn more about the default settings for the agent. After you create the agent, don't switch to a smaller VM instance with less CPU or RAM.
If you receive notifications that your agent VM is under-provisioned, consider upgrading to a larger VM instance with more CPU or RAM.
If you installed the agent in vCenter, use the Console maintenance tool to resize the VM instance. Learn how to resize the agent VM in vCenter. |
If you need to increase the CPU or RAM of your agent VM, follow the instructions provided by your cloud provider or on-premises virtualization platform to resize the VM instance. NetApp recommends doubling the current CPU and RAM allocation to ensure optimal performance. The following table shows recommended sizing tiers, with each tier doubling the CPU and RAM of the previous tier.
| Tier | CPU (cores or vCPUs) | RAM |
Minimum |
8 |
32 GB |
Medium |
16 |
64 GB |
Large |
32 |
128 GB |
Monitor the agent
Stay informed about disk space, RAM, and CPU problems on your agent VM so that you can resolve them.
The Console notifies you when the agent VM is unhealthy, including disk space, RAM, and CPU issues. Monitor these notifications in the Notifications Center within the Console or configure email notifications. Occasional increases in disk space, memory, or CPU usage are normal, but if it happens frequently, you should take steps to resolve.
For example, the Console notifies you when an agent resource (CPU, RAM, or disk space) exceeds 90% of its total capacity for 30 consecutive minutes. Afterwards, if the resource usage drops below that threshold, the notification displays as resolved (green) in the Notifications Center.
Work with NetApp Support if you have questions about modifying your agent VM. |
| Notification | Action needed |
Disk space is too high |
CPU usage is too high |
Increase the CPU size of the agent VM in your cloud provider or on-premises, depending on where you installed it. Alternatively, create additional agents and distribute the workload across multiple agents. |
RAM usage is too high |
Increase the RAM of the agent VM in your cloud provider or on-premises, depending on where you installed it. Alternatively, create additional agents and distribute the workload across multiple agents. RAM utilization can vary based on your environment, ONTAP workloads, number of Cloud Volumes ONTAP systems, and the data services that you are using. |
Stop and start the agent VM
Limit downtime when you stop and start the agent VM, because management and data services depend on the agent staying operational.
If you need to, stop and start the agent VM using your cloud provider's console or standard on-premises procedures.
Connect to the Linux VM
Check the status of the Console agent from its Linux VM so that you can confirm that it's running.
If you need to connect to the Linux VM that the agent runs on, use the connectivity options from your cloud provider.
- AWS
When you create the agent instance in AWS, provide an AWS access key and secret key. You can use this key pair to SSH to the instance. Use the user name 'ubuntu' for the EC2 Linux instance. For agents created prior to May 2023, use the user name 'ec2-user'.
- Azure
When you create the agent VM in Azure, you specify a user name and choose to authenticate with a password or SSH public key. Use the authentication method that you chose to connect to the VM.
- Google Cloud
You can't specify an authentication method when you create an agent in Google Cloud. However, you can connect to the Linux VM instance using the Google Cloud Console or Google Cloud CLI (gcloud).
