Prerequisites for NetApp Volume Caching
Get started by verifying the readiness of your operational environment, login, network access, and web browser.
To use Volume Caching, you should ensure that your environment meets all requirements.
ONTAP 9.8 and later
Cluster Admin ONTAP permissions
Intercluster LIFs on the clusters
In the NetApp Console:
The Console agent needs to be set up in the NetApp Console. All source and target clusters must be on the same Console agent. Refer to the Getting started workflow for NetApp Console and Learn about Console agents.
The working environment should be set up.
The clusters should be added in the target working environment and in an ON or degraded state.
Standard NetApp Console requirements. Refer to NetApp Console requirements.
