Configuring the Brocade Sphereon/Intrepid Switch data collector
Data Infrastructure Insights uses the Brocade Sphereon/Intrepid Switch (SNMP) data collector to discover inventory for Brocade Sphereon or Intrepid switches.
Requirements
The following requirements must be met in order to configure this data collector:
There must be IP connectivity to all switches in the fabric. If you select the Discover all switches in the fabric check box, Data Infrastructure Insights identifies all the switches in the fabric; however, it needs IP connectivity to these additional switches to discover them.
Read-only community string if using SNMP V1 or SNMP V2.
HTTP access to the switch to obtain zoning information.
Access validation by running the snmpwalk utility to the switch (see <install_path>\bin\).
Configuration
| Field | Description |
Sphereon Switch |
IP address or fully-qualified domain name of the switch |
SNMP Version |
SNMP version |
SNMP Community String |
SNMP read-only community string used to access the switch |
SNMP User Name |
SMI-S user name for the switch (SNMP v3 only) |
SNMP Password |
SMI-S password for the switch (SNMP v3 only) |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 15 minutes. |
SNMP Auth Protocol |
SNMP authentication protocol (SNMP v3 only) |
SNMP Privacy Password |
SNMP privacy password (SNMP v3 only) |
SNMP Number of Retries |
Number of SNMP retry attempts |
Fabric Name |
Fabric name to be reported by the data collector. Leave blank to report the fabric name as WWN. |
Enable Trapping |
Select to enable acquisition upon receiving an SNMP trap from the device. If you select enable trapping, you must also activate SNMP. |
Minimum Time Between Traps (seconds) |
Minimum time between acquisition attempts triggered by traps. The default is 10 seconds. |
Performance Poll Interval (sec) |
Interval between performance polls. The default is 300 seconds. |
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
