Configuring the EMC VNXe data collector
The DELL EMC VNXe data collector provides inventory support for VNXe unified storage arrays. Data Infrastructure Insights currently supports iSCSI and NAS protocols.
Requirements
The VNXe data collector is CLI based; you must install the Unisphere for VNXe CLI, (uemcli.exe) onto the acquisition unit where your VNXe data collector resides.
uemcli.exe uses HTTPS as the transport protocol, so the acquisition unit will need to be able to initiate HTTPS connections to the VNXe.
IP address or fully-qualified domain name of the VNXe device
You must have at least a read-only user for use by the data collector.
IP address of the managing Solutions enabler server.
HTTPS on Port 443 is required
The EMC VNXe data collector provides NAS and iSCSI support for inventory; fibre channel volumes will be discovered, but Data Infrastructure Insights does not report on FC mapping, masking, or storage ports.
Terminology
Data Infrastructure Insights acquires the following inventory information from the VNXe data collector. For each asset type acquired by Data Infrastructure Insights, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
| Vendor/Model Term | Data Infrastructure Insights Term |
Disk |
Disk |
Storage Array |
Storage |
Processor |
Storage Node |
Storage Pool |
Storage Pool |
General iSCSI Block info, VMware VMFS |
Share |
Replication Remote System |
Synchronization |
iSCSI Node |
iSCSI Target Node |
iSCSI Initiator |
iSCSI Target Initiator |
Note: These are common terminology mappings only and might not represent every case for this data source.
Configuration
| Field | Description |
VNXe Storage |
IP address or fully-qualified domain name of the VNXe device |
User Name |
User name for the VNXe device |
Password |
Password for the VNXe device |
Advanced configuration
Inventory Poll Interval (min) |
Interval between inventory polls. The default is 40 minutes |
CLI Port |
Port used for the VNXe CLI |
Performance poll interval (sec) |
The default is 300. |
Troubleshooting
Some things to try if you encounter problems with this data collector:
Inventory
| Problem: | Try this: |
"Failed to execute external utility" with error messages “Failed to find Unisphere executable uemcli” |
* Verify correct IP address, username, and password |
Additional information may be found from the Support page or in the Data Collector Support Matrix.
