Data Infrastructure Insights
IBM TotalStorage DS4000 data collector
Contributors netapp-alavoie dgracenetapp
This data collector acquires inventory and performance information from the IBM DS4000 storage system. There are two possible configurations (firmware 6.x and firmware 7.x+), and they both have the same values.
Terminology
Data Infrastructure Insights acquires the following inventory information from the IBM DS4000 data collector. For each asset type acquired, the most common terminology used for this asset is shown. When viewing or troubleshooting this data collector, keep the following terminology in mind:
Vendor/Model Term Data Infrastructure Insights Term
Disk
Disk
Volume Group
Disk Group
Storage Array
Storage
Controller
Storage Node
Volume Group
Storage Pool
Volume
Volume
Note: These are common terminology mappings only and might not represent every case for this data collector.
Requirements
  • IP address of each DS5 or FAStT array
  • Access validation by pinging the IP address of both controllers on the array
  • Port requirements: 2463
Configuration
Field Description
Comma-separated list of Array SANtricity Controller IPs
IP addresses and/or fully-qualified domain names for the array controllers
Advanced configuration
Field Description
Inventory Poll Interval (min)
Default is 30 minutes
Performance Poll Interval up to 3600 seconds
Default is 300 seconds
Troubleshooting
Additional information on this Data Collector may be found from the Support page or in the Data Collector Support Matrix.
