NetApp Data Classification
Scan data sources with NetApp Data Classification
Contributors netapp-ahibbard
NetApp Data Classification scans the data in the repositories (the volumes, database schemas, or other user data) that you select to identify personal and sensitive data. Data Classification then maps your organizational data, categorizes each file, and identifies predefined patterns in the data. The result of the scan is an index of personal information, sensitive personal information, data categories, and file types.
After the initial scan, Data Classification continuously scans your data in a round-robin fashion to detect incremental changes. Scans are automatically conducted every day. Data Classification conducts scans in batches of six; you can pause scans or manually prioritize them.
You can enable and disable scans at the volume level or at the database schema level.
Understand scan types
You can conduct two types of scans in Data Classification:
  • Map-only scans provide only a high-level overview of your data and are performed on selected data sources. Map-only scans take less time than full scans because they don't access files to see the data inside.
  • Full scans provide deep-level scanning of your data. A full scan includes a mapping scan and a classification of data inside the files.
Tip Performing a map-only scan can be helpful in gaining an overview of your data. With this high-level overview, you can then decide which data sources you want to conduct full scans on.
Review the tables to see what information is surfaced in map-only scans and full scans.
Feature Full scan Map-only scan
Scan speed
Slow
Fast
Pricing
Free
Free
Capacity
Limited to 500 TiB*
Limited to 500 TiB*
List of file types and used capacity
Yes
Yes
Number of files and used capacity
Yes
Yes
Age and size of files
Yes
Yes
Ability to run a Data Mapping Report
Yes
Yes
Data Investigation page to view file details
Yes
No
Search for names within files
Yes
No
Create saved queries that provide custom search results
Yes
No
Ability to run other reports
Yes
No
Ability to see metadata from files**
Yes
Yes
* Data Classification does not impose a limit on the amount of data it scans. Each Console agent supports scanning and displaying 500 TiB of data. To scan more than 500 TiB of data, install another Console agent then deploy another Data Classification instance.
The Console UI displays data from a single connector. For tips on viewing data from multiple Console agents, see Work with multiple Console agents.
** The following metadata is extracted from files during mapping scans:
  • File discovered time
  • File last accessed
  • File last modified
  • File type
  • File size
  • File creation
  • Number of files
  • Permissions extraction
  • Storage repository
  • System
  • System type
  • Used capacity
Governance dashboard differences:
Stale data
Yes
Yes
Non-business data
Yes
Yes
Duplicated files
Yes
Yes
Predefined saved queries
Yes
No
Default saved queries
Yes
Yes
DDA report
Yes
Yes
Mapping report
Yes
Yes
Sensitivity level detection
Yes
No
Sensitive data with wide permissions
Yes
No
Open permissions
Yes
Yes
Age of data
Yes
Yes
Size of data
Yes
Yes
Categories
Yes
No
File types
Yes
Yes
Compliance dashboard differences:
Personal information
Yes
No
Sensitive personal information
Yes
No
Privacy risk assessment report
Yes
No
HIPAA report
Yes
No
PCI DSS report
Yes
No
Investigation filters differences:
Saved queries
Yes
Yes
System type
Yes
Yes
System
Yes
Yes
Storage repository
Yes
Yes
File type
Yes
Yes
File size
Yes
Yes
Created time
Yes
Yes
Discovered time
Yes
Yes
Last modified
Yes
Yes
Last accessed
Yes
Yes
Open permissions
Yes
Yes
File directory path
Yes
Yes
Category
Yes
No
Sensitivity level
Yes
No
Number of identifiers
Yes
No
Personal data
Yes
No
Sensitive personal data
Yes
No
Data subject
Yes
No
Duplicates
Yes
Yes
Classification status
Yes
Status is always "Limited insights"
Scan analysis event
Yes
Yes
File hash
Yes
Yes
Number of users with access
Yes
Yes
User/group permissions
Yes
Yes
File owner
Yes
Yes
Directory type
Yes
Yes
