NetApp Ransomware Resilience
Manage alerts in NetApp Ransomware Resilience
Contributors netapp-ahibbard amgrissino
When NetApp Ransomware Resilience detects a possible attack, it displays an alert on the dashboard and in the Notifications menu and immediately takes a snapshot. Review the alert in the Alerts tab to assess the risk to your data and decide on a response.
If Ransomware Resilience detects a possible attack, a notification appears in the Console Notification settings, and an email is sent to the configured addresses. The email includes information about the severity, the impacted workload, and a link to the alert in the Ransomware Resilience Alerts tab.
You can dismiss false positives or start recovery immediately.
Tip If you dismiss the alert, Ransomware Resilience learns this behavior, associates it with normal operations, and stops sending alerts on similar events.
To begin recovery, mark the alert as ready for recovery so your storage administrator can start the recovery process.
Each alert might include multiple incidents on different volumes and statuses. Review all incidents.
How alerts are generated
Ransomware Resilience relies on evidence about data entropy patterns, file extension types, and encryption to produce alerts. Alerts are based on the following events:
  • Data breach
  • Data destruction
  • File extensions were created or changed
  • File creation with a comparison of detected versus expected rates
  • File deletion with a comparison of detected versus expected rates
  • Suspicious user behavior
  • When encryption is high, without file extension changes
Note For data breach, data destruction, and suspicious user behavior alerts, you must configure user activity detection. You can also prevent specific file paths and users from generating alerts.
Alert types and statuses
Alerts have one of two statuses: New or Inactive.
An alert is classified as one of the following types:
  • Potential attack: An alert is classified as a potential attack when:
    • Autonomous Ransomware Protection detects a new extension and the occurrence is repeated more than 20 times in the last 24 hours (default behavior).
    • Data breaches are detected.
    • Data destruction is detected.
  • Warning: A warning occurs based on the following behaviors:
    • Detection of a new extension has not been identified before and the same behavior does not repeat enough times to declare it as an attack.
    • High entropy is observed.
    • File read, write, rename, or delete activity doubled compared to normal levels.
Note For SAN environments, warnings are based on high entropy only.
Evidence is based on information from Autonomous Ransomware Protection in ONTAP. For details, refer to Autonomous Ransomware Protection overview.
Alert states
An alert incident can have the following states:
State
New
All incidents are marked "new" when they are first identified.
In review
You can manually mark an alert incident as "in review" while you evaluate it.
Dismissed
If you suspect that the activity is not a ransomware attack, you can change the status to "dismissed."
CAUTION: After you dismiss an attack, you can't revert its status. If you dismiss a workload, all snapshot copies taken automatically in response to the potential ransomware attack will be permanently deleted.
Resolved
The incident has been fixed.
Auto Resolved
For low priority alerts, the incident is automatically resolved if there has been no action taken on it within five days.
Note If you have an existing protection strategy and then disable one form of detection on it, any alerts created under the previous iteration of the policy can only be marked as "Resolved" not "Dismissed." For example, if you had an active alert for a protection strategy that included encryption detection and suspicious user behavior but then disabled encryption detection, you can only mark that alert as "Resolved."
View alerts
You can access alerts from the Ransomware Resilience dashboard or from the Alerts tab.
Required Console role
To perform this task, you need the Super admin, Ransomware Resilience admin, or Ransomware Resilience viewer role. Learn about Ransomware Resilience roles for NetApp Console.
Steps
  1. In the Ransomware Resilience dashboard, review the Alerts pane.
  2. Select View all under one of the statuses.
  3. Select an alert to review all incidents on each volume for each alert.
  4. To review additional alerts, select Alert in the breadcrumbs at the upper left.
  5. Review the alerts on the Alerts page.
    Alerts page
  6. Continue with one of the following:
Respond to an alert email
When Ransomware Resilience detects a potential attack, it sends an email notification to the subscribed users based on their subscription notification preferences configured in the NetApp Console settings. The email contains information about the alert, including the severity and resources impacted.
Tip To set up email notifications in the Console, see Set email notification settings.
Steps
  1. View the email.
  2. In the email, select View alert and log in to Ransomware Resilience.
    The Alerts page appears.
  3. Review all incidents on each volume for each alert.
  5. Continue with one of the following:
Detect malicious activity and anomalous user behavior
Looking at the Alerts tab, you can identify whether there is malicious activity or anomalous user behavior.
You must have configured a user activity agent and enabled a protection policy with user behavior detection to view user-level alerts. The Suspicious user column appears in the Alerts dashboard only when user behavior detection is enabled. For more information, learn about user activity detection.
View malicious activity
When Autonomous Ransomware Protection triggers an alert in Ransomware Resilience, you can view the following details:
  • When the alert was triggered
  • When access was changed or denied
  • Entropy of incoming data
  • Expected creation rate of new files compared to detected rate
  • Expected deletion rate of files compared to detected rate
  • Expected rename rate of files compared to detected rate
  • Impacted workloads, volumes, files, and directories
Note These details are viewable for NAS workloads. For SAN environments, only the entropy data is available.
Steps
  1. From the Ransomware Resilience menu, select Alerts.
  2. Select an alert.
  3. Review the incidents in the alert.
    Alert incidents page
  4. Select an incident to review the details of the incident.
View anomalous user behavior
If you've configured user behavior detection, you can view user-level data and block specific users. To enable user activity detection, see Configure agents and collectors.
Steps
  2. Select an alert.
    1. To block a suspected user in your environment, select Block next to the user's name.
    2. To disable alerts on a given user who is the subject of an alert you know to be false, select the three dots (…​) then Exclude this user from monitoring. Review the dialog then select Exclude to confirm.
    3. In the Responses tile, select Take snapshot now to create a snapshot.
    4. If you've enabled an automated response on the SVM, select Edit user blocking to block the user. To block the user, select Time period for blocked user then set the duration of the block (anywhere from one hour to permanent). You can also unblock the user if you believe the alert is not a ransomware event. Select Save.
Tip To re-enable alerts for a user, return the alert. Select the three dots then Include this user in monitoring. You can also Exclude users from monitoring.
Mark ransomware incidents as ready for recovery (after incidents are neutralized)
After stopping the attack, notify your storage administrator that the data is ready so they can initiate the recovery process.
To perform this task, you need the Super admin or Ransomware Resilience admin role. Learn about Ransomware Resilience roles for NetApp Console.
Steps
    Alerts page
  2. In the Alerts page, select the alert.
  4. If you determine that the incidents are ready for recovery, select Mark restore needed.
  5. Confirm the action and select Mark restore needed.
  6. To initiate the workload recovery, select Recover workload in the message or select the Recovery tab.
Result
After the alert is marked for restore, the alert moves from the Alerts tab to the Recovery tab.
Dismiss incidents that are not potential attacks
After you review incidents, you need to determine whether the incidents are potential attacks. If they aren't actual threats, they can be dismissed. If you dismiss an alert, all snapshot copies taken automatically in response to a potential ransomware attack are permanently deleted.
For alerts prompted by encryption (entropy) events, Ransomware Resilience learns from your dismissal of the alert to associate the activity with normal operations; in the future, you won't receive alerts based on this type of activity. This is because encryption (entropy) events are managed by ARP/AI. For alerts prompted by other events, Ransomware Resilience does not learn from the dismissal as these alerts are based on user activity patterns.
Caution If you dismiss an alert, you can't change its status or undo this change.
Steps
    Alerts page
  3. Select one or more incidents. Alternately, select all incidents by selecting the Incident ID box at the top left of the table.
  4. If you determine that the incident is not a threat, dismiss it as a false positive:
    • Select the incident.
    • Select the Edit status button above the table.
      Alert Edit Status page
  5. From the Edit status box, choose the Dismissed status.
    Additional information about the workload and the snapshot copies are deleted appears.
  6. Select Save.
    The status on the incident or incidents changes to "Dismissed."
View a list of impacted files
Before you restore a workload at the file level, you can view a list of impacted files. You can access the Alerts page to download a list of impacted files. Then use the Recovery page to upload the list and choose which files to restore.
Steps
Use the Alerts page to retrieve the list of impacted files.
Tip If a volume has multiple alerts, you might need to download the CSV list of impacted files for each alert.
  2. On the Alerts page, sort the results by workload to show the alerts for the workload that you want to restore.
  3. From the list of alerts for that workload, select an alert.
  4. For that alert, select a single incident.
    list of impacted files for a specific alert
  5. For that incident, select the download icon to download the list of impacted files in CSV format.
