NetApp Ransomware Resilience
Review recovery status in NetApp Ransomware Resilience
Contributors amgrissino netapp-ahibbard
After a workload is marked Restore needed, NetApp Ransomware Resilience recommends a recovery point actual (RPA) and guides you through the recovery workflow.
  • If the VM is managed by NetApp Backup and Recovery or Ransomware Resilience, Ransomware Resilience performs a crash-consistent restore so all data from the same point in time is restored, as it would be after a system crash.
    You can restore the workload by selecting all volumes, specific volumes, or specific files.
Tip Workload recovery can affect running workloads. Coordinate recovery processes with the appropriate stakeholders.
A workload can have one of the following restore statuses:
  • Restore needed: The workload needs to be restored.
  • In progress: The restore operation is currently underway.
  • Restored: The workload has been restored.
  • Failed: The workload restore process could not be completed.
View workloads that are ready to be restored
Review the workloads that are in the "Restore needed" recovery status.
Steps
  1. From the main Ransomware Resilience dashboard, review the "Restore needed" totals in the Alerts pane and select View all.
    Alternately, select Recovery from the sidebar.
  2. Review the workload information in the Recovery page.
    Recovery page
Recover a workload
After you assess the workloads, you have two options to restore your workload:
