Set up licensing for NetApp Backup and Recovery
Contributors guillermotome
Set up licensing for NetApp Backup and Recovery in NetApp Console or NetApp Console local deployment by using a marketplace subscription or a bring-your-own license (BYOL) from NetApp. A valid license is required to activate the service, create backups, and restore data to production systems.
A few notes about how licenses work:
  • When using ONTAP Volumes workloads, you can discover and restore volumes without a license. However, if you need to protect (back up) volumes, you need to purchase a license.
  • If you are using Backup and Recovery with NetApp Console local deployment, you can only purchase a bring-your-own-license (BYOL) license.
  • The NetApp Backup and Recovery bring-your-own-license (BYOL) is a floating license that you can use across all systems associated with your NetApp Console organization or account. So if you have sufficient backup capacity available from an existing BYOL license, you won't need to purchase another BYOL license.
  • If you are using a BYOL license with NetApp Console, it is recommended that you subscribe to a PAYGO subscription as well. If you back up more data than allowed by your BYOL license, or if the term of your license expires, then backup continues through your pay-as-you-go (PAYGO) subscription - there is no disruption of service.
  • When backing up on-premises ONTAP data to StorageGRID, you need a BYOL license, but there's no cost for cloud provider storage space.
Licensing options for NetApp Backup and Recovery
You have three licensing options for NetApp Backup and Recovery:
  • Purchase a direct license, also known as a bring-your-own-license (BYOL), from NetApp. This option applies to both NetApp Console and Console local deployment.
  • Purchase an annual contract from a hyperscaler marketplace. This option applies to NetApp Console only.
  • Subscribe to a pay-as-you-go (PAYGO) license from a hyperscaler marketplace. This option applies to NetApp Console only.
30-day free trial
A 30-day NetApp Backup and Recovery free trial is available for all unlicensed workloads except ONTAP Volumes workloads. You can start the trial when you begin using a workload, before discovering its resources. After you start the trial, its status and used capacity appear under Free Trials on the NetApp Backup and Recovery home page.
End the free trial
You can end the free trial for a workload at any time from the home page that appears when you log in to NetApp Backup and Recovery. If you want to continue using NetApp Backup and Recovery after the free trial ends, you must set up a paid subscription in the Licenses and subscriptions section of the NetApp Console interface. If you don't want to continue using NetApp Backup and Recovery, you can end the free trial without subscribing to a paid plan. You can unregister NetApp Backup and Recovery from the system before the trial ends and you won't be charged.
Steps
  1. From the NetApp Backup and Recovery home page, choose the free trial you want to end under Free trials.
  2. Select End free trial.
  3. Type end trial in the box.
  4. Select End trial to confirm.
Use a BYOL license
Bring-your-own licenses from NetApp provide 1-, 2-, or 3-year terms. You pay only for the data that you protect, calculated by the logical used capacity (before any efficiencies) of the source ONTAP volumes which are being backed up. This capacity is also known as Front-End Terabytes (FETB).
The BYOL NetApp Backup and Recovery license is a floating license where the total capacity is shared across all systems associated with your NetApp Console organization or account. For ONTAP systems, you can get a rough estimate of the capacity you'll need by running the CLI command volume show -fields logical-used-by-afs for the volumes you plan to back up.
If you don't have a NetApp Backup and Recovery BYOL license, select the chat icon in the lower-right of the Console to purchase one.
Optionally, if you have an unassigned node-based license for Cloud Volumes ONTAP that you won't be using, you can convert it to a NetApp Backup and Recovery license with the same dollar-equivalence and the same expiration date. Go here for details.
You use NetApp Console or NetApp Console local deployment to manage BYOL licenses. You can add new licenses, update existing licenses, and view license status from the Console.
Use a marketplace license (applies to NetApp Console only)
Pay for NetApp Backup and Recovery annually by purchasing an annual contract. They're available in 1-, 2-, or 3-year terms.
If you have an annual contract from a marketplace, all NetApp Backup and Recovery consumption is charged against that contract.
When you use AWS, there are two annual contracts available from the AWS Marketplace page for Cloud Volumes ONTAP and on-premises ONTAP systems:
  • A "Cloud Backup" plan that enables you to back up Cloud Volumes ONTAP data and on-premises ONTAP data.
    If you want to use this option, set up your subscription from the Marketplace page and then associate the subscription with your AWS credentials. Note that you'll also need to pay for your Cloud Volumes ONTAP systems using this annual contract subscription since you can assign only one active subscription to your AWS credentials in the Console.
  • A "CVO Professional" plan that enables you to bundle Cloud Volumes ONTAP and NetApp Backup and Recovery. This includes unlimited backups for the Cloud Volumes ONTAP system using the license (backup capacity is not counted against the licensed capacity). This option doesn't enable you to back up on-premises ONTAP data.
    See the Cloud Volumes ONTAP licensing topic to learn more about this licensing option.
    If you want to use this option, you can set up the annual contract when you create a Cloud Volumes ONTAP system and the Console prompts you to subscribe to the AWS Marketplace.
When you use Azure, there are two annual contracts available from the Azure Marketplace page for Cloud Volumes ONTAP and on-premises ONTAP systems:
    If you want to use this option, set up your subscription from the Marketplace page and then associate the subscription with your Azure credentials. Note that you'll also need to pay for your Cloud Volumes ONTAP systems using this annual contract subscription since you can assign only one active subscription to your Azure credentials in the Console.
    If you want to use this option, you can set up the annual contract when you create a Cloud Volumes ONTAP system and the Console prompts you to subscribe to the Azure Marketplace.
When you use GCP, contact your NetApp sales representative to purchase an annual contract. The contract is available as a private offer in the Google Cloud Marketplace.
After NetApp shares the private offer with you, you can select the annual plan when you subscribe from the Google Cloud Marketplace during NetApp Backup and Recovery activation.
Use a NetApp Backup and Recovery PAYGO subscription (applies to NetApp Console only)
For pay-as-you-go, you pay your cloud provider for object storage costs and NetApp backup licensing costs on an hourly basis in a single subscription. You should subscribe to NetApp Intelligent Services in the Marketplace even if you have a free trial or bring your own license (BYOL):
  • Subscribing ensures that there's no disruption of service after your free trial ends. When the trial ends, you'll be charged hourly according to the amount of data that you back up.
  • If you back up more data than allowed by your BYOL license, then data backup and restore operations continue through your pay-as-you-go subscription. For example, if you have a 10 TiB BYOL license, all capacity beyond the 10 TiB is charged through the PAYGO subscription.
You won't be charged from your pay-as-you-go subscription during your free trial or if you haven't exceeded your BYOL license.
There are a few PAYGO plans for NetApp Backup and Recovery:
  • A "Cloud Backup" package that enables you to back up Cloud Volumes ONTAP data and on-premises ONTAP data.
  • A "CVO Professional" package that enables you to bundle Cloud Volumes ONTAP and NetApp Backup and Recovery. This includes unlimited backups for the Cloud Volumes ONTAP system using the license (backup capacity is not counted against the licensed capacity). This option doesn't enable you to back up on-premises ONTAP data.
    This option also requires a Backup and Recovery PAYGO subscription, but eligible Cloud Volumes ONTAP systems do not incur charges.
Use these links to subscribe to NetApp Backup and Recovery from your cloud provider marketplace:
Exceeding license capacity
Exceeding your licensed capacity triggers PAYGO rates. Without a PAYGO subscription, you cannot create new backups, though you can still restore existing backups without a service guarantee. Renew your license before it expires because an expired license prevents new backups and disrupts service.
What happens when your license expires
When your Backup and Recovery license expires:
  • Backups from existing backup policies and restores continue to work.
  • You can't create new backup policies or extend protection to additional workloads and datastores.
  • You can't use new Backup and Recovery features and enhancements.
  • NetApp technical support for Backup and Recovery is no longer available.
Renew your license to:
  • Create and modify backup policies, including policies for application-consistent backups of databases, VMs, and Kubernetes workloads.
  • Use new Backup and Recovery features and enhancements.
  • Continue to receive NetApp technical support.
