SANtricity commands
Delete host port - SANtricity CLI
Contributors netapp-driley netapp-maumita
The delete hostPort command deletes a host port identification.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
The identification is a software value that represents the physical host port to the controller. By deleting the identification, the controller no longer recognizes instructions and data from the host port.
Important
This command does not work in an iSCSI environment, where the host ports are considered initiators. Instead, use the delete iscsiInitiator command. See Delete iSCSI initiator.
Syntax
delete hostPort [hostPortName]
Parameter
Parameter Description
hostPort
The name of the host port that you want to delete. Enclose the name of the host port in square brackets ([ ]). If the host port name contains special characters or consists only of numbers, you also must enclose the name in double quotation marks (" ") inside square brackets.
Notes
A host port is a physical connection on a host adapter that resides within a host computer. A host port provides a host access to the volumes in a storage array.
Minimum firmware level
5.20
