Reset storage array iSCSI baseline - SANtricity CLI
The reset storageArray iscsiStatsBaseline command resets the iSCSI baseline to 0 for the storage array.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, and E5700 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, or E5700 storage array, you must have the Storage Admin role.
This command is deprecated and is replaced by the Reset storage array host port statistics baseline command. |
Syntax
None.
Notes
This command resets the baseline to 0 for both controllers in the storage array. The purpose of resetting both of the controller baselines is to help make sure that the controller counts are synchronized between the controllers. If one controller resets but the second controller does not reset, the host is informed that the controllers are out of synchronization. The host is informed by the time stamps that are reported with the statistics.
Minimum firmware level
7.10
8.41 This command is deprecated.
