SANtricity commands
Reset storage array host port statistics baseline - SANtricity CLI
Contributors netapp-driley
The reset storageArray hostPortStatisticsBaseline command resets the storage array host port statistics baseline.
Supported Arrays
This command applies to an individual E4000, E2800, E5700, EF600, EF300, EF50, and EF80 storage arrays. It does not operate on E2700 or E5600 storage arrays.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
Syntax
reset storageArray hostPortStatisticsBaseline type=(ISCSI| ISER | SRP | NVMEOF)
Parameter Description
type
Allows you to indicate which statistics type to collect. Valid choices are: ISCSI, ISER, SRP, and NVMEOF.
Minimum firmware level
8.41
