SANtricity commands
Enable disk pool security - SANtricity CLI
Contributors netapp-driley netapp-maumita
The enable diskPool security command converts a non-secure disk pool to a secure disk pool.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin role.
Context
Note
All of the drives that comprise the disk pool must be secure-capable.
Syntax
enable diskPool [diskPoolName] security
Parameter
Parameter Description
diskPool
The name of the disk pool that you want to place in the Security Enabled state. Enclose the disk pool identifier in square brackets ([ ]).
Notes
Each disk pool name must be unique. You can use any combination of alphanumeric characters, underscore (_), hyphen (-), and pound (#) for the user label. User labels can have a maximum of 30 characters.
Minimum firmware level
7.83
