Show storage array unconfigured iSCSI initiators - SANtricity CLI
The show storageArray unconfiguredIscsiInitiators command returns a list of initiators that have been detected by the storage array but are not yet configured into the storage array topology.
Supported Arrays
This command applies to any individual storage array, including the E4000, E2700, E5600, E2800, E5700, EF600, EF300, EF50, and EF80 arrays, as long as all SMcli packages are installed.
Roles
To execute this command on an E4000, E2800, E5700, EF600, EF300, EF50, or EF80 storage array, you must have the Storage Admin or Storage Monitor role.
This command is deprecated. The command that replaces it is show storageArray unconfiguredInitiators.
Syntax
None.
Minimum firmware level
7.10
8.50 deprecated this command.
